> Vibrating too much
post Apr 19, 2008 - 10:04 PM
mikecelica
Joined Jan 31, '07
From Ontario, Canada
I've noticed for a while that my car vibrates alot, at first I thought maybe all cars do this, but they dont. All I have on is header,muffler,CIA, the steering wheel vibrates alot especialy while in neutral. Anyone know why this is? And at idle you hear this hissing noise, its the intake but why does it hiss so loud? thanks for any help
Replies (1 - 9)
post Apr 19, 2008 - 10:16 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
What does your car idle at? The hissing is probably a vacuum leak. The vibration could be caused by a shot motor mount. Do the inspections.
94 Celica gt white (sold)
post Apr 19, 2008 - 10:52 PM
mikecelica
Joined Jan 31, '07
Idles at around 1000rpm, where are the vacuum hoses? Is it possible to see the bad motor mount by popping the hood, or do I need to get under?
This post has been edited by mikecelica: Apr 19, 2008 - 10:54 PM
post Apr 19, 2008 - 11:24 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
You can go under the car and inspect the rear motor mount and front mount. Its right on the cross member. 1000rpm is high. We should be idleing around 750. You def. have a vac leak. Vac hoses are normally found on your intake manifold. Just sprak soapy water or brake cleaner while the car is idleing. If you hear the car get louder than thats where your leak is.
post Apr 20, 2008 - 3:21 PM
celicaboy92
Joined Mar 10, '08
From columbia, MO
it maybe u need a front or rear alignment my steering wheel used to shake alot before i got one
post Apr 20, 2008 - 4:00 PM
mikecelica
Joined Jan 31, '07
QUOTE(bccentaur3 @ Apr 20, 2008 - 4:24 AM) [snapback]666312[/snapback]
Spray the soapy water right on the intake manifold? I checked it out it doesnt look like any loose hoses not plugged? WHat should I be looking for, unplugged hoses?
post Apr 26, 2008 - 6:28 PM
6_GEN
Joined Feb 23, '08
From Indiana
You should look for cacks in the hoses.If you are idling at 1000 then it must be a small leak,if something was to be unplugged then your rpm's would go above 3000
If you have an aftermarket intake then the hiss comes from that.Actualy if your hoses have never been changed,this is a good time to change them all.They are all hard and brittle after 10+ years.
post Apr 26, 2008 - 8:39 PM
st18
Joined Nov 20, '07
From Oil City Louisiana
i agree with the check the motor mounts and the trans mount my car does the same thing with the shaking and i have chattering in the brake pedal the dealer ship will check them for you they will be cracked and what not but thats what imo it is i had 2 replaced and it got a lot better and now i have 2 more to replace to see if it will stop. by the way those things are freaking high $ to get so good luck hope every thing works out
post Apr 26, 2008 - 9:24 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
As already mentioned, it can be:
1: small vaccum leak (easy fix)
2: bad mount (moderate fix)
3: misfire (moderate to moderately hard fix)
4: low compression (aww crap)
post Apr 28, 2008 - 12:50 AM
tonytutino
Joined Jun 16, '06
From Bowling Green KY
you hit any potholes lately man? that did it for me... bent my damn rim and now if i hit 60+ my car shakes like a bat outta hell
Lo-Fi Version Time is now: February 17th, 2025 - 6:28 AM
