> Trunk Hatch, Can't get my trunk to release
post Apr 21, 2008 - 10:19 PM
bseaman_5
Joined Apr 6, '08
From Overland Park
So the other day I went to pop my hatch and the trunk wouldn't open. I pull the trunk release and it's like it's already release but the trunk doesn't open and it doesn't release.. I tried the key in the back and same story.. I don't have a clue on how to get my trunk open or how to get this fixed.. Any ideas would be much appreciated...
I can pull the release and I can hear the cord moving all the way to the back but it just won't release..
Replies (1 - 6)
post Apr 23, 2008 - 12:29 PM
brk34
Joined Jan 20, '08
did you try opening the trunk with the key? Hold the key all the way and pull open the trunk. This happens on my celica.
also try this thread
http://www.6gc.net/forums/index.php?showto...52&hl=lever
post Apr 23, 2008 - 5:41 PM
bseaman_5
Joined Apr 6, '08
From Overland Park
I've tried the key I've tried everything I can think of. . The key doesn't do anything. It will turn and the cord will move but its like it won't actually release. Idk if its jammed or what. Its not that it doesn't pop up, it doesn't ever let loose. It doesn't release the part that holds it. There is no resistance when I turn the key or pull the release. It's like it's just slipping or not even grasping to release whatever holds it down.
This post has been edited by bseaman_5: Apr 23, 2008 - 5:52 PM
post Apr 23, 2008 - 6:24 PM
2bcelica
Joined Mar 22, '07
From Murphy, TX
you have to go inside of the car and pull down the back seats - crawl to the trunk and release the cable/latch manually -- the mechanism popped out of place -- you might have to remove the plastic covering of the back to do this - this happened to me a few times and thats what i had to do -
post Apr 23, 2008 - 10:45 PM
bseaman_5
Joined Apr 6, '08
From Overland Park
QUOTE(2bcelica @ Apr 23, 2008 - 6:24 PM) [snapback]667473[/snapback]
ok, how do I release it manually?? I can't figure it out. I tried messing with it with a flat head but was very unefective that way.. and I'm not sure how to remove the plastic when its stuck shut.. not a whole lot of room to move that stuff around..
post Apr 24, 2008 - 2:44 AM
-mo-
Joined Apr 11, '08
From clearwater
sounds like the cable came unattached as mentioned....removal of rear plastic may be in order...remove all the plugs holding it and lift up...
post Apr 24, 2008 - 8:38 AM
bseaman_5
Joined Apr 6, '08
From Overland Park
Easy fix. . Ha. Thanks for the help!
Lo-Fi Version Time is now: November 29th, 2024 - 8:48 AM
