> How do you remove the bar in front of the fuse box?
post Apr 24, 2008 - 12:00 AM
xredjokerx
Joined Apr 18, '08
From Oakland, bay area, California
i was wondering how i could remove the bar in front of the fuse box below the steering wheel. i want to put in a switch but its too deep runs into the metal. if i could remove that bar, it'd fit properly. also, is it necessary to have that metal bar there? thanks for the responses guys!
Replies (1 - 8)
post Apr 25, 2008 - 10:49 AM
Muggs
Joined Sep 13, '06
From St. paul, MN
QUOTE(xredjokerx @ Apr 24, 2008 - 12:00 AM) [snapback]667577[/snapback]
I'm having the same problem. I'm going to remove the lower dash panel in a few days and find out if that bar is removable. if not, I'm just going to cut a chunk out so it clears my switch.
post Apr 25, 2008 - 1:31 PM
xredjokerx
Joined Apr 18, '08
oo good luck man lemme know how it goes.. for now, im debating hitting the junkyard for stock hole plastic pieces and i might just mount it onto the plastic piece... but yeah.. whats yours wired to?
post May 1, 2008 - 12:05 AM
Muggs
Joined Sep 13, '06
From St. paul, MN
Well it was actually a plate made of some composite/hard plastic material. 4 bolts hold it on and it has no apparent purpose so I removed it, and it gave me plenty of clearance. The switch is an oem style fog light switch, and I plan on tapping into a fuse from that fuse block for power.
post May 1, 2008 - 1:23 AM
6strngs
Joined May 12, '06
From Wilmington, NC
I think it's there to keep you from sliding under the dash during an accident. the plastic piece alone isn't gonna stop you.
post May 1, 2008 - 3:18 AM
xredjokerx
Joined Apr 18, '08
how did u remove it? are the four bolts hard to remove? did u have to remove the bottom of the dash? haha im dying to remove mine lol
post May 1, 2008 - 9:50 AM
6strngs
Joined May 12, '06
From Wilmington, NC
remove the platic dash piece on the underside of the steering column, there's a couple screws that hold it in. then you remove the four 10 or 12 mm bolts (can't remember the size) and it comes off.
post May 1, 2008 - 6:19 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
QUOTE(6strngs @ Apr 30, 2008 - 11:23 PM) [snapback]669803[/snapback]
post May 2, 2008 - 2:27 PM
xredjokerx
Joined Apr 18, '08
nice! thanks for those quick instructions. dude i missed the screw inside the fuse slot and i broke it >__> oh well, otherwise the rest of the installation went great. thanks again for your help man!
Lo-Fi Version Time is now: December 4th, 2024 - 9:18 AM
