> intalling a push start...
post Sep 3, 2003 - 11:19 PM
macavely
Joined Nov 4, '02
Just wanted to know if anyone has tried doing this? or even thought about it?
Replies (1 - 12)
post Sep 4, 2003 - 1:27 AM
If you're talking about a S2000-style push button starter, John(Mynzeyes) has it in his car where his cigarette lighter is, and it looks sweet. I considered doing it to my car, but I already have remote start, and so I wouldn't use it much. If you want to do it, the wiring is pretty basic, and we could help you out with it. smile.gif
post Sep 6, 2003 - 12:03 PM
SiKBOY
Joined Nov 4, '02
From Sydney, Australia
I've got a push button starter sitting in my room waiting to be installed but the instructions are in Japanese. One of these days I will get off my ass and get it deciphered.
post Sep 6, 2003 - 6:37 PM
Mynzeyes
From Franklin/Nashville, TN
um..it's really easy to install. there are 4 wires to hook up, there's a ground, a constant power, and an accessory power...theeeen, the 4th is the ignition wire, which you splice into a wire in the back of the ignition cylinder, i'll have to check which wire that is tho, cause i don't recall off the top of my head...i'll explain it a little better later, when i'm not tryin to get 3" of water out of the corolla's trunk... frown.gif
-John-
AIM==Mynzeyes
post Sep 6, 2003 - 8:06 PM
Cody
Joined Dec 11, '02
From Sioux Falls, SD, USA
...do you still have to turn the key to "on" though?
post Sep 6, 2003 - 8:40 PM
macavely
Joined Nov 4, '02
does any one have a diagram on how to do it??
post Sep 6, 2003 - 8:56 PM
QUOTE (Cody @ Sep 6, 2003 - 5:06 PM)
Yes, you'd still need to turn the key to "on" in order to start the car, with most setups anyway.
And Mac, I can draw up a diagram for you when I get home a little bit later. smile.gif
post Sep 6, 2003 - 10:19 PM
SiKBOY
Joined Nov 4, '02
I was wondering, if the push button starter is installed, is it possible to start the car up normally as well as pushing the button? or can you only start the car with the push button starter. I wanted my push button starter to act like a kill switch in that I plan to install the push button starter in a "secret" place incase someone tries to steal my car with a screwdriver jammed in the ignition. ( I've seen it done)
post Sep 6, 2003 - 10:32 PM
QUOTE (SiKBOY @ Sep 6, 2003 - 7:19 PM)
You could wire it up either way. If you don't want to be able to start the car with a key, then you could cut the starter wire before it reaches the ignition switch, and hook up the push button starter to the other side of the wire. wink.gif
post Sep 6, 2003 - 10:33 PM
kingpreetham
Joined Jul 8, '03
From Dallas, TX
is there a way to eliminate the key, probably by using another switch....
post Sep 6, 2003 - 10:39 PM
QUOTE (kingpreetham @ Sep 6, 2003 - 7:33 PM)
Yes, it can be done. I'm not sure how though. There must be a key-in-ignition wire somewhere, because without the key in, the car's steering wheel will lock up, even if the car is on.
post Sep 7, 2003 - 12:26 AM
kingpreetham
Joined Jul 8, '03
From Dallas, TX
it would be interesting to do, is there any spec on the ignition system, a wiring diagram or something....
post Sep 7, 2003 - 5:07 AM
Here is a link to how to do this, and here is another one. Neither are for sixth generation Celicas specifically, but it gives you the basic idea. wink.gif
Lo-Fi Version Time is now: November 25th, 2024 - 12:34 PM
