> 6th gen noob turbo ?'s!!!, Some questions on turbo'in a 5sfe
post May 28, 2008 - 12:07 AM
Chrishan
Joined May 28, '08
From canada
Hey all, The girl ive been with for a few years now picked up a 97 celica gts from an X boss of mine, and now that she has had it for a year, and me doing the work on it and helpingher pick out some parts for it, We want to turbo it.
Me being a Nisdan guy with a S13 240, It's different from the old easy SR20 swap or RB and ca, etc.
Anyways my questions are,
-what kind of turbo parts from other celicas can we use ? ( 3sgte manifold )?
-Is it a tough job to do on the 97 gts, ( no air lot's of space )
-The car has 190k at low boost would it be ok to run a turbo set up?
-IS there anywhere that makes a decently priced complete turbo kit?
Replies (1 - 4)
post May 28, 2008 - 1:06 AM
southwest2118
Joined Jan 13, '06
QUOTE (Chrishan @ May 28, 2008 - 12:07 AM) *
post May 28, 2008 - 2:19 AM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
stickies... http://www.6gc.net/forums/index.php?showtopic=29705
post May 28, 2008 - 2:44 PM
D-Man
Joined Jan 18, '08
From Houston
First check out the stickys under FORCED INDUCTION
Then:
(again, i'm not being mean)
And to answer your questions directly:
Depends on what engine you have (Canadian GTS is 5sfe?)
No harder than the rest (except for the already turbo-charged GT-4)
Low boost should be okay, but look into a rebuild soon.
No Kit is avalible.
Damn D-Man - most impressive.
post May 28, 2008 - 2:49 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
You're asking if you can run boost on a 190k mile motor. If you are a car guy you would know that a healthy motor isn't told by the mileage on it. Its told from a leak down test and a little on a compression test.
Talking about swapping in sr20's in a 240 being easy, the 3s swap is easy.
94 Celica gt white (sold)
Lo-Fi Version Time is now: February 21st, 2025 - 3:18 PM
