> How do you program new remote?, factory alarm
post Jun 10, 2008 - 1:01 PM
gt_driFFter
Joined Nov 29, '04
Toyota Dealership wants me to make an appointment for something I know only takes 5 minutes. I just need to know where the box is, and what the "sequence" is to program my new remote (that the dealership raped me for)!
Thanks
Replies (1 - 8)
post Jun 10, 2008 - 1:51 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
the box is under the driverseat.
1. Insert key into ignition, turn it to on(not acc)
2. On your ECU unit, gently push the button with the
tip of a paper clip, pen, etc, for about 3 seconds until the light on
the TOYOTA SECURITY panel lights up. You now have about 30 seconds to
press the button on your new remote once) to tell the car to
recognize it.
3. remove key from ignition
4. step out of car and test your remote
that should do it.
post Jun 10, 2008 - 2:27 PM
gt_driFFter
Joined Nov 29, '04
post Jun 10, 2008 - 3:47 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
No problem. did that one work? because i also remember one where you had to open and close the door 5 times or something then unlock and lock it 3 times then go back and forth from off to Acc with the key 5 times then you could program it.
post Jun 10, 2008 - 4:05 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
This information is SUH-WEEEET!!!!
post Jun 10, 2008 - 6:16 PM
gt_driFFter
Joined Nov 29, '04
It worked PERFECT for my new (to me) 98 GT! Thanks again!
BTW, I think this could maybe be a sticky?
post Jul 5, 2008 - 10:42 AM
STlad
Joined Oct 3, '07
From Ireland
Ok tried looking for that box, no joy!
Could you post a pic of what the box under the seat looks like?
I took apart the dash looking for a control box with a button but nothing... not a zip? The car doesnt have an aftermarket alarm for sure, the toyota security led is there and no aftermarket boxes anywhere. All the boxes are labeled TVS-IIIB, again not one with a button
post Jul 5, 2008 - 10:56 AM
lubu
Joined Apr 2, '07
From Great Western Plateau
QUOTE (STlad @ Jul 5, 2008 - 11:42 PM) *
In mine it sits on top of the ECU under the centerdash, black box. Not really a button that you can push with ur finger, you need a pen or something small.
98% completion
aaRon
post Jul 5, 2008 - 7:59 PM
STlad
Joined Oct 3, '07
From Ireland
hmm does it look like this???
This box I found just above the air vents in the center dash, theres a "key transponder" box on the passenger side. I found no buttons on either!? I even unscrewd that one and opened it up the only button looking thing is a set of dip-switches which I take are for setting the frequency.
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: January 14th, 2025 - 5:51 PM
