GT-FOUR owners, I need your help |
Jun 23, 2008 - 5:46 AM |
Enthusiast Joined Jun 20, '08 From Moscow, Russia Currently Offline Reputation: 0 (0%) |
hi, everyone!
I've got an APEX'i AVC-R boost controller. Would you be so kind as to share your adjustments/figures with me if anyone got the same device? I'm interested in duty figures most thanx in advance |
Jun 23, 2008 - 3:47 PM |
Enthusiast Joined Jan 9, '05 From Under the car Currently Offline Reputation: 0 (0%) |
1.1 bar at 57% duty
1.3 bar at 63% duty But these are the settings I used to use....all of them if its any help Setting [A] 0.9 Bar Boost /Duty Cycle Bst = 0.90kg/cm2 Duty = 52% NE Point NE1 = 3000 NE2 = 3500 NE3 = 4000 NE4 = 4500 NE5 = 5000 NE6 = 5500 NE7 = 6000 NE8 = 6500 F/B Speed 1S = 5 2N = 5 3R = 5 4T = 5 5T = 5 Learn Gear 1S = x 2N = x 3R = x 4T = x 5T = x Start Duty Set to 0% in all Setting [B] 1.1 Bar Boost /Duty Cycle Bst = 1.10kg/cm2 Duty = 60% NE Point NE1 = 3000 NE2 = 3500 NE3 = 4000 NE4 = 4500 NE5 = 5000 NE6 = 5500 NE7 = 6000 NE8 = 6500 F/B Speed 1S = 5 2N = 5 3R = 5 4T = 5 5T = 5 Learn Gear 1S = x 2N = x 3R = x 4T = x 5T = x Start Duty Set to 0% in all Etc settings Car Select Cyl = 4 Spd = 5 Throttle = / (arrow pointing up to the right) Sensor Select Number one (1) Gear Jdge 1st = 120 2nd = 075 3rd = 050 4th = 035 5th = 025 N/S = 255 Graph Scale BS = 2.0kg/cm2 Ne = 8000 RPM Sp = 300km/h Monitor 2 Channel 1 Bst 2 Rev This post has been edited by Insanity-74: Jun 23, 2008 - 3:48 PM |
Jun 24, 2008 - 12:54 AM |
many thanx
Lo-Fi Version | Time is now: November 25th, 2024 - 11:53 AM |
