clutch install questions, random questions about installing a clutch |
Jun 30, 2008 - 6:17 PM |
Enthusiast Joined Oct 4, '06 From va Currently Offline Reputation: 0 (0%) |
So I’m about to put a clutch in my bone stock 94 st (my first clutch install), and have a few questions.
First of all: From what I’ve read on the site I’ll probably go with an exedy oem, and just get my existing flywheel machined. Also, I have the Haynes manual for the car as well as the pdfs from celicatech to guide me. Question 1: What else should be done while everything is taken apart? I know rear main, and axle seals, is there anything else? Question 2: Are there any special tools that are necessary or will make the job easier/faster? Question 3: How high does the car need to be jacked up to have clearance to get the transmission out? I saw in the “auto to manual swap” how to it says 2.5ft for the rear and 3ft for the front, I have jack stands but they don’t even begin to approach that height, so I don’t know if this measurement is not made from the bottom of the stand to the top or if I just need taller jack stands… Basically I’m concerned with safety; it seems like the car will become less stable the higher it is, so I don’t want it any higher than it has to be… I’m pretty much looking for the best advice on how to do the job without the car falling on me and terminating my life force. Thanks for any help. This site is bad ass by the way. |
Jul 1, 2008 - 7:47 AM |
Enthusiast Joined Feb 8, '04 From Thornton, CO. Currently Offline Reputation: 1 (100%) |
if its been a while you could always bleed the system. but thats the only thing i can think of this early.
no special tools cept when i did my clutch i lucked out and found some hydraulic jack stands at checker (jack stands that you can pump up to get where you need then lock in place.) i used em throughout the whole car, jacked the front up, and placed one under the engine and one under the tranny. i didnt jack the back up just placed chocks behind the wheels with parking brake on. but be careful with the tranny, its pretty awkward and weighs like 30lbs. i got like a million pics from when i did mine if you want. lemme know -------------------- Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..." |
Jul 1, 2008 - 9:36 PM |
yeah if its not too much trouble pics would be awesome, might come in handy...
thanks |
Jul 3, 2008 - 1:14 AM |
Not a problem at all.
Dont forget to drain your tranny fluid! Pictures of all the bolts you will need to break loose prior to breaking off bellhousing bolts: (there should be two bolts on the starter if i remember right, couldnt get a pic of that but make SURE you get that first) bolts for slave cylinder- Bolt for hose for slave cylinder- Bolts for shift linkage and speedo (there are some cotter pins on the shift linkage end that will need to be pulled as well, no pic avail for that sorry)- Bolt for wiring harness- disconnect batt, jack car up, get tires off and then... Yank the cotter pin here and unbolt the hub- Place jack under engine and tranny and keep it level, begin unbolting bellhousing. once bolts are loose get the front, rear and driver side motor mounts (way harder than i make it sound... the rear mount will leave you with the need for group therapy if its your first time doing a clutch on a fw). once you have the tranny out yank the pressure plate and flywheel and get it machined down to awesomeness (if your machinist doesnt catch it, its a stepped flywheel) Torque to spec (see bgb) and align everything with the flywheel using the alignment tool. Reverse your steps making sure to torque everything down and your gold jerry... GOLD.... lemme know if you have any questions. -------------------- Fred
Jul 4, 2008 - 10:20 PM |
awesome thanks man
Lo-Fi Version | Time is now: January 16th, 2025 - 5:48 AM |
