> Door Shell
post Jun 30, 2008 - 7:43 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
Could I use a door shell from a car that doesnt have power windows?tnx
God made man....
Everything else...
Made in China
Replies (1 - 5)
post Jun 30, 2008 - 7:54 PM
QUOTE (nics @ Jun 30, 2008 - 8:43 PM) *
the best one to answer this would be griffg.
I dont see why not, there is no reason toyota would have made diferrent shells, all you plug in is the accesories....
post Jun 30, 2008 - 8:20 PM
97Celica
Joined Nov 27, '02
From Derry,NH USA
more than likely...I've seen the inside of both...they look the same.
post Jul 1, 2008 - 8:57 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
Just plug and play right? no other extra components except that it the door came from a car w/ manual windows.
God made man....
Everything else...
Made in China
post Jul 1, 2008 - 9:11 AM
D-Man
Joined Jan 18, '08
From Houston
yeah, you just wouldn't Plug in the Power Window's wiring. Just make sure it's taped off, even if it is in a harness. Just incase wink.gif
This post has been edited by D-Man: Jul 1, 2008 - 9:11 AM
Damn D-Man - most impressive.
post Jul 2, 2008 - 1:43 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
The answer is yes, mostly. It'll be a slight PITA, but not too terrible and definitely do-able.
All the window stuff, power or manual, bolts in to the inside shell (not to be confused with the door panel). Actually, now that I think about it, the mechanism for the locks (power or manual) bolts onto the shell and the side panel (the part where the door latches). You'll need to swap out the door lock actuator from your car to the new shell. It's pretty easy to do though - there's 3 screws on the side panel, just above the latch, that bolt in the door lock stuff.
I'll be completing my window conversion this weekend, so if you can hold off 'till Monday if you need pix, I should be posting up photos by then.
Lo-Fi Version Time is now: December 1st, 2024 - 9:25 PM
