Aug 4, 2008 - 10:39 PM
Enthusiast ![]() ![]() Joined Jun 16, '07 From Vancouver, Canada Currently Offline Reputation: 14 (100%) |
Hey Guys, I'm not sure if this should be in the off-topic or in engine maintenance. I started this topic in engine cause it partly related to the 6 gen celica. I've been working on a 88 celica with a 3sge engine trying to gain some experience in swapping before i do my 95 celica.
The plan was to swap out the usdm block and internals for a jdm block and its internals because the usdm crankshaft was badly damaged. During this swap I've encountered a few differences, for example the pistons are different (jdm have wedge top as where usdm have a flat top). The one difference that I'm stuck on is the flywheel. The usdm flywheel (11-1/4") is smaller than jdm flywheel (12") and the hole for mounting are slightly off. The jdm flywheel is actually a 5sfe flywheel. I know that both celica uses The S53 tranny, so is there anyway to make a hybrid flywheel? or some sort of setup that would work. * usdm starter is in a difference place compared to the 5sfe starter I need the size of a usdm flywheel with the mounting holes of a 5sfe flywheel. If you guys have any tips or suggestions that would be awesome, THANKS! -------------------- ![]() |
Aug 5, 2008 - 10:47 AM
use the flywheel for the specific crank. you dont want sizing issues. in alot of toyota cases the flywheels are a little different but the same clutch will fit and work. as for the pistons being flat or wedged, that to change the compression
Aug 5, 2008 - 3:08 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
I can make you any type of hybrid clutch you need, just let me know what flywheel you're using and which transmission.
-Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Aug 5, 2008 - 7:22 PM
use the flywheel for the specific crank. you dont want sizing issues. in alot of toyota cases the flywheels are a little different but the same clutch will fit and work. as for the pistons being flat or wedged, that to change the compression The only problem to that is if we use the jdm flywheel (5sfe) the starter is not going to fit. I can make you any type of hybrid clutch you need, just let me know what flywheel you're using and which transmission. -Doc Thanks Doc! let me ask the other guys if that's the road we are going to take. This post has been edited by vile_v: Aug 5, 2008 - 7:23 PM -------------------- ![]() |
| Lo-Fi Version | Time is now: May 15th, 2026 - 8:21 AM |
