Enthusiast ![]() Joined Jan 8, '08 From Sweden Currently Offline Reputation: 0 (0%) ![]() |
Hi!
I have the basic four speakers and no amp in my car. Now it is time to get an amp and a sub. I don't know much about this stuff so I'm grateful for all help I can get. I'm right nog thinking about buying a 4 channel amp and connect two of the channels to the sub and the other two to my current speakers. Is this a good idea? Is it even possible? Is there any big differents between 10" and 12" subs? I want a relative small sub so that i can use my trunk without takeing the sub out. ![]() //Johan This post has been edited by Ugglan: Aug 6, 2008 - 3:03 AM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) ![]() |
i would just have an audio shop do the installation so that way its sure fire the first time, but if its not then they should be able to fix it free of charge since they did it. i personally think 10's can slamm more than the same in 12's. just have to match everything i mean everything.
i would just have an audio shop do the installation so that way its sure fire the first time, but if its not then they should be able to fix it free of charge since they did it. i personally think 10's can slamm more than the same in 12's. just have to match everything i mean everything. I'm not worried about the fysical connections, I just want to know if it is a good idea so that i can order the amp and the sub, then I will worry about how to put it together... ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) ![]() |
I think it depends on the subbox, I just bought a 15" and it isnt that big.
-------------------- ![]() 98% completion --- aaRon |
I think it depends on the subbox, I just bought a 15" and it isnt that big. Yeah, your right. I just heard that a 10" is "faster" and sounds better i general, but I guess I have to try to listen to a sub before I buy it. More intrested in which amp i should get, if a 4-channel is a good idea or not... This post has been edited by Ugglan: Aug 6, 2008 - 6:15 AM |
Enthusiast ![]() Joined Jun 12, '08 From houston Currently Offline Reputation: 0 (0%) ![]() |
i bridged all my connections 2 12" subs and all 4 6" rounds off of one amp you can do it 4 channels are worthless u enver need more than 2
If ur planning to power the speakers as well then I suggest you get the AB or B class amps (A class is just too damn expensive), if you're just gonna power the sub alone then get some D class amp.
If ur planning to power the speakers as well then I suggest you get the AB or B class amps (A class is just too damn expensive), if you're just gonna power the sub alone then get some D class amp. Good thinking, will look into a AB or B class amp then, A seems way to expensive ![]() Didn't tought about he classes before so tanks... |
![]() Enthusiast ![]() ![]() Joined Dec 12, '06 From Fob Sharana, Afghanistan Currently Offline Reputation: 2 (100%) ![]() |
Alot of you people are forgetting a valuable information for people who are just getting into sound systems.
Mono Amp = Low frequency amplifier and the best one for powering subwoofers, but you cannot amplify speakers. 2 Channel Amp = Amplifies 1 pair of speakers and subwoofers. You can do 2 pairs of speakers but you will lose the 'fade' feature. 4 Channel Amp = Allows you to amplify 2 pairs of speakers and subwoofers. Keep in mind that if you want the best power out of your subwoofers, use a Mono Amp. Alot of times, people would use a Mono Amp to amplify their subwoofers and a 4 Channel Amp to amplify their speakers. But if you're on a budget and just want to get by on a basic setup, go with a Mono Amp for thump. But if you plan on amplifying your speakers as well, go ahead with 2 and 4 Channel Amps. But PLEASE, do not amplify your factory speakers. They aren't made to be amplified. Keep in mind that 'factory speakers' are made of PAPER and will go pretty quick. There are two kinds of speakers, PAPER and POLYURETHANE. Paper = Good at low frequencies, bad at mid and high frequencies. Polyurethane = Bad at low frequencies, good at mid and high frequencies. Low frequencies = Bass!!! Mid frequencies = Instrumentals High frequencies = Vocals Most aftermarket speakers are made of Polyurethane and that is why they give you that clear crisp sound that everyone likes out of speakers. Most 2 Channel and 4 Channel Amps will amplify mids and highs on speakers where as subwoofers will only draw in low frequencies. Having polyurethane speakers and subwoofers is the best setup and will give you the best balance of lows, mids, and highs. That is the key of a good sound system. And yes, when it comes to aftermarket speakers and subwoofers, BRAND name does matter! This post has been edited by FortuneCookie: Aug 7, 2008 - 2:17 PM |
Tank you FortuneCookie!
A really good answer, tanks alot! ![]() I have change my speakers once so the paper factory speakers are gone...and it made a big difference in the sound. Now it's time for step two, the sub and an amp. Now I know what to buy and how to do it, just to wait till the end of the month to get some money to spend. ![]() Again, really good explanation FortuneCookie!!! |
Alot of you people are forgetting a valuable information for people who are just getting into sound systems. Mono Amp = Low frequency amplifier and the best one for powering subwoofers, but you cannot amplify speakers. 2 Channel Amp = Amplifies 1 pair of speakers and subwoofers. You can do 2 pairs of speakers but you will lose the 'fade' feature. 4 Channel Amp = Allows you to amplify 2 pairs of speakers and subwoofers. Keep in mind that if you want the best power out of your subwoofers, use a Mono Amp. Alot of times, people would use a Mono Amp to amplify their subwoofers and a 4 Channel Amp to amplify their speakers. But if you're on a budget and just want to get by on a basic setup, go with a Mono Amp for thump. But if you plan on amplifying your speakers as well, go ahead with 2 and 4 Channel Amps. But PLEASE, do not amplify your factory speakers. They aren't made to be amplified. Keep in mind that 'factory speakers' are made of PAPER and will go pretty quick. There are two kinds of speakers, PAPER and POLYURETHANE. Paper = Good at low frequencies, bad at mid and high frequencies. Polyurethane = Bad at low frequencies, good at mid and high frequencies. Low frequencies = Bass!!! Mid frequencies = Instrumentals High frequencies = Vocals Most aftermarket speakers are made of Polyurethane and that is why they give you that clear crisp sound that everyone likes out of speakers. Most 2 Channel and 4 Channel Amps will amplify mids and highs on speakers where as subwoofers will only draw in low frequencies. Having polyurethane speakers and subwoofers is the best setup and will give you the best balance of lows, mids, and highs. That is the key of a good sound system. And yes, when it comes to aftermarket speakers and subwoofers, BRAND name does matter! Good post! The factory speakers are made to be amplified, infact all speakers can be amplied. Its just a matter of how much can they handle before the core starting to dislocate, but I am sure thats what you mean ![]() -------------------- ![]() 98% completion --- aaRon |
Lo-Fi Version | Time is now: February 21st, 2025 - 11:39 PM |
