JDM tails, Fog light issue |
Aug 11, 2008 - 2:32 PM |
Enthusiast Joined Feb 4, '08 From UK Currently Offline Reputation: 0 (0%) |
Hi guys, I recently installed some JDM tails and they look great. However I couldn't work out how to set up the rear fog lights.
My car is an import and im in the UK so rear fogs are a legal requirement - Im presuming here that the JDM tails don't have fog lights built into them? Cause i certainly can't see it! My next question is that the previous owner rigged up a switch on the dash to turn the rear fogs on, however with the new JDM lights when switched nothing happens to the rear but when I brake the front fogs flash (turn on) = weird!!!! Is this some suspect dodgy wiring job that Im going to have to investigate and redo? Or this a common problem? Any help would be great!!! Ta! -------------------- |
Aug 11, 2008 - 3:00 PM |
Enthusiast Joined Apr 22, '07 From Buckinghamshire, UK Currently Offline Reputation: 2 (100%) |
hey dude. Why don't you post on the UK forums....more likely to get help there.
Sounds like the rear fogs were wired to work concurrently with the fronts. You need to isolate the curcuits/ Have a look at the wiring under the steering column and inspect with a multimeter. I have the same tails and I just fitted an aux fog under the bumper. |
Aug 11, 2008 - 3:05 PM |
Enthusiast Joined Jan 2, '08 From Scotland Currently Offline Reputation: 3 (100%) |
I cut the fog wiring and converted the offside revering lamp into a fog
-------------------- Regards
frisp HKS Super Power Flow Induction Kit, HKS Silent Hi Power Exhaust, Fensport Decat, SS-III Spolier Projector Lights, LED JDM Tails, GT4 Nose, Tein Super Street coilover kit, 17" Aerospeed RSGT's, White dash LED's JDM Wind Deflectors, TRD Quick Shift, Stainless Sill Covers. Gen 7 leather, 3VZ-FE 3ltr V6 To be done.... Ganador mirrors, 2 Pot BrakesStainless brake lines, Decent Disks/pads |
Aug 11, 2008 - 3:50 PM |
Enthusiast Joined Aug 3, '07 From Bellevue, Nebraska Currently Offline Reputation: 28 (100%) |
are you using the wiring harness that came with the JDM's? because the wiring harnesses are univeral... last i checked, so you should be able to use the one that works.
-------------------- ~Andy
Check out my Droid Goodies | My Flickr |
Aug 12, 2008 - 1:34 AM |
Enthusiast Joined Sep 17, '05 From Newcastle / UK Currently Offline Reputation: 4 (100%) |
I rewired my inner stop lamps to be rear fogs, pretty easy really.
-------------------- 1994 JDM GT4 WRC
Aug 12, 2008 - 5:56 PM |
Ah, that makes sense!!! I am using the wiring harness that came with the JDM's but the previous owner has obviously done some tinkering and done some odd wiring - I think i'll modify the offside reverse lamp to a fog and whilst im at it rewire the switch so that it doesn't come on with the brakes!!!
Thanks for the ideas guys!! Mucho appreciated!!! -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 2:40 PM |
