> 2-Jz Swap
post Aug 14, 2008 - 7:42 PM
DatDudeJoey
Joined Jan 23, '08
Has anyone done a 2 jz swap to a celica?
Replies (1 - 11)
post Aug 14, 2008 - 7:43 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
post Aug 14, 2008 - 8:20 PM
paul_gt4
Joined Jun 22, '08
From Derry Northern Ireland
i know of a few 2-jz done in Lexus IS200's a guy over here in Northern Ireland is building an 800bhp model which is nearly completed
don't think it would be feasible in a fwd and can't be done i don't think in the gt4 (with gearbox and transfer not mating), it would be a serious costly with new mounts and frame modification.
post Aug 14, 2008 - 9:49 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
forget that idea.
if you tried to mate it to your gearbox and keep fwd (a silly idea because of the power and torque even a stock 2jz would produce would be enough to smash your gearbox if you ever managed to get traction, and would be so heavy in the front)
you could do it rwd (a guy in aus has a 1uz-fetz (yes its twin turbo and supercharged) in a st185 gtfour, but a 1uz is only 4 cyl long, it involved a lot of fabrication and engineering, a 2jz is obviously longer, it would have cylinder 1 where your radiator is. its not feasable.
put in a 3sgte, 1mz/3vz, or leave it like it is.
GRX133 Toyota Mark X 350s
post Aug 14, 2008 - 10:40 PM
ZGear
Joined Feb 16, '07
From BP, MN
IT'S BEEN DONE!!!!!
With the power of Photoshop........hmmmm......yes we can keep dreaming....
post Aug 14, 2008 - 11:33 PM
Rusty
Joined Nov 5, '07
From New Zealand
older Celica's like the 3rd and 4th Gens have had 2JZ put into them I'm pretty sure
post Aug 15, 2008 - 12:15 AM
b18tuner5875
Joined Aug 12, '08
From Grand Rapids, MI
how about a 1 jz? would the .5 liter difference make it fit better?
signature under construction
current cars:
91 Red Toyota Mr2 Turbo (my toy)
90 Toyota Corolla LE (dd, soon to be sold)
94 6th Gen Black ST (my new dd and new toy)
post Aug 15, 2008 - 3:41 AM
Cuts_the_Pilot
Joined Dec 15, '02
no 1jz are the same dimentions.
and ide like to add that the 2jz in that photo is wrong because the turbos are on the driver side (ok well drivers side for us rhd'ers)
nice work on the photoshopping, did you mirror?
post Aug 15, 2008 - 4:02 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE (ZGear @ Aug 14, 2008 - 8:40 PM) *
IT'S BEEN DONE!!!!!
+1
post Aug 15, 2008 - 7:59 AM
ZGear
Joined Feb 16, '07
From BP, MN
QUOTE (Cuts_the_Pilot @ Aug 15, 2008 - 9:41 AM) *
LOL.....yeah it was a quickie....had to find one with the same angle as the car...
post Aug 15, 2008 - 8:19 AM
DEATH
Joined Dec 19, '07
From tx
QUOTE (Rusty @ Aug 14, 2008 - 11:33 PM) *
1st, 2nd and 3rd gens been done - 4th is even more improbable than ours because the bay is setup nearly the same with the radiator pushed nearly 6" farther back and considerably less room to work with than ours wink.gif
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Aug 15, 2008 - 9:50 AM
Taskbot
Joined Jun 6, '08
From Hamiltron, Ontario
Its probably impossible with our engine bay. However longitudinal engine mounted celi's can do it for sure. But IMO its probably a useless idea and not worth it.
If you want a RWD car, it probably cheaper to buy one. Probably even cheaper to buy a 3rd/4th Gen Supra than build it out of a Celica.
If you're really determined on a RWD celica you can probably use the subframe from a MR-2 or another Celica and custom build a MR Celica.
Here's a build of an MR Integra which should probably deter you from cutting up you Celica:
Team Integra mid engined H22A4 conversion
This post has been edited by Taskbot: Aug 15, 2008 - 9:51 AM
(\__/)
Lo-Fi Version Time is now: January 10th, 2025 - 11:20 AM
