> Gauge cluster and warning lights not lighting up., burnt bulbs or cluster problem?
post Aug 19, 2008 - 8:28 PM
Por2geezcelica
Joined Aug 17, '08
From NY
I just picked up a 96 celica for cheap, and the gauge cluster doesnt light up. Only the tach lights up and the warning lights underneath it light up, but the speedo, temp and fuel gauge and the warning lights on the right side of the cluster dont light up. The car has almost 200k miles, so could this be caused by the bulbs being burnt out, or is there something wrong with the cluster or wiring?
Replies (1 - 9)
post Aug 19, 2008 - 9:57 PM
slow_yota
Joined Mar 3, '07
From Sunny Florida
try the 7.5 panel fuse under the drivers side dash...or just burnt bulbs..The panel fuse is a much easier fix though.
post Aug 19, 2008 - 10:30 PM
Por2geezcelica
Joined Aug 17, '08
From NY
do you know which fuse in the panel underneath the dash is for the gauge cluster?
post Aug 19, 2008 - 10:48 PM
it's the fuse labeled "gauge"
post Aug 19, 2008 - 10:59 PM
hitcachi
Joined Jun 19, '05
From Nebraska
laugh.gif taking apart the guage bezel is really easy too in case you want to check the bulbs or the wiring and what not. Takes 5 to 10 mins.
post Aug 19, 2008 - 11:04 PM
Por2geezcelica
Joined Aug 17, '08
From NY
QUOTE (Batman722 @ Aug 19, 2008 - 11:48 PM) *
haha well thats easy enough. ill take a look tomorrow, see if its the fuse. If not, ill switch out the bulbs. Are the bulbs available at an autozone or napa?
post Aug 19, 2008 - 11:40 PM
Culpable04
Joined Apr 17, '06
From New Jersey
yes
post Aug 19, 2008 - 11:44 PM
Por2geezcelica
Joined Aug 17, '08
From NY
Ok great, thanks.
post Aug 20, 2008 - 7:23 PM
Por2geezcelica
Joined Aug 17, '08
From NY
so i checked the fuse and it was fine, then i replaced the bulbs and the speedo, temp and gas gauge light up now. But with the key in the on position when the cars off, the only warning light that lights up on the right side is the check engine light. On the left side the airbag, battery, oil, door, and brake light are on if the car is off and the key is in the on position. Are there supposed to be more warning lights on?
post Aug 27, 2008 - 12:38 PM
reko
Joined Apr 17, '07
From Montreal, QC, Canada
QUOTE (Por2geezcelica @ Aug 20, 2008 - 8:23 PM) *
No
Lo-Fi Version Time is now: November 30th, 2024 - 6:07 AM
