> transmission drain plug., i got under the car and it was stripped. any suggestions on how to get
post Sep 6, 2008 - 9:27 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
i tried to use vice grips to get my stripped plug loose, but they kept on sliding off. any suggestions on how to get it off. i don't have a torch.
Replies (1 - 15)
post Sep 6, 2008 - 9:31 PM
QUOTE (garin @ Sep 6, 2008 - 10:27 PM) *
tight vice grips and a little hammer. hit it couple at times. make sure is tight..
i used these
post Sep 6, 2008 - 9:43 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
so you think i should maybe try a new pair of vice grips? the one's i have now are old. my dad had them lying around.
post Sep 6, 2008 - 9:47 PM
thats how i did it
post Sep 6, 2008 - 11:05 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
still can't get it off. i've been playing with this foe like an hour and a half now. do you recommend smaller vice grips? any other ideas maybe?
post Sep 7, 2008 - 1:42 AM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
i wouldnt advise using a straight nose vice grips
use the ones that are more like butt nose pliers, like the following.
tap the head of the bolt with a hammar, this will aid the "cracking" of the bolt.
also get some of that can freeze sh!t, duno if you guys have it over there, its a loctite product its a preasure pack can that sprays out has at -30 deg c or something, spray it on the bolt head immediatly before you try to undo it. Making metals colder (below 0 c) shrinks them, making it easier again.
conversly if you like get some gas (oxy acet) onto the box itself to heat it up (dont heat the bolt head) obviously heating expands the metal around the bolt head. If your not experienced with gas i dont advise.tongue.gif
GRX133 Toyota Mark X 350s
post Sep 7, 2008 - 11:57 AM
dont heat an aluminum transmission with a torch.
a set of craftsman bolt outs or something similar will work just fine. get a new drain plug and gasket from the dealer.
post Sep 7, 2008 - 12:23 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
bolt outs?
post Sep 7, 2008 - 12:37 PM
QUOTE (garin @ Sep 7, 2008 - 1:23 PM) *
bolt outs?
yes
post Sep 7, 2008 - 12:50 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
if i go to sears and ask they will have it?
post Sep 7, 2008 - 1:01 PM
AE102
Joined Sep 1, '08
From Chester,UK
get a "stud extractor kit". drill into the bolt, tap in splined extractor, slip the slider on and spanner off.
saved me a few times - excellant piece of kit!
This post has been edited by AE102: Sep 7, 2008 - 1:01 PM
post Sep 7, 2008 - 2:10 PM
QUOTE (garin @ Sep 7, 2008 - 1:50 PM) *
yes
post Sep 7, 2008 - 2:14 PM
QUOTE (AE102 @ Sep 7, 2008 - 2:01 PM) *
not neaded, the bolt out will grab onto it and get it out.
that way risks breaking off a bit of hardened steel inside the plug, now you have a hole in your drain plug with a piece of hardened steel inside of it that makes drilling it any further nearly impossible. and now its leaking because of the hole in it...and you have metal shavings inside the trans.
only drill a drain plug as a LAST resort.
post Sep 7, 2008 - 9:02 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
so vice grips didn't work out at all. i don't really wanna drill it either. i guess i'm gonna take it to the shop... unless there are any other ideas. bolt out was too small. only up to 19 mm. the tranny plug is 24mm.
post Sep 7, 2008 - 9:42 PM
AE102
Joined Sep 1, '08
From Chester,UK
QUOTE (Bitter @ Sep 7, 2008 - 3:14 PM) *
you dont drill all the way through the plug so no way of swarf entering the box. used it many times and never had a problem. if you take it to the garage they'll use an extracor.
i trust you've tried tapping a smaller socket on - sometimes if i'm lucky an imperial socket will fit with a bit of persuasion.
post Sep 7, 2008 - 9:56 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
yeah i've tried different sized wrenches, metric and standard.
Lo-Fi Version Time is now: February 19th, 2025 - 7:34 PM
