> Project sound insulation, Determined to get rid of some road noise
post Sep 13, 2008 - 3:56 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
Alright guys, I decided to tackle a project similar to what a member on here did by getting rid of some noise with a carpeting material. I'm attempting the same thing, except with my door panels and rear panels. I went to Home Depot and bought a 6'x9' roll of carpet padding for $30, along with a can of 3M rubber and vinyl spray adhesive. I already tried to deaden the sound a bit by using some extra Dynamat I had, but it didn't help much at all. Spray the door panel on the areas where you will be placing the padding, then rip pieces to the size of your choice and place accordingly. WARNING: You might want to let these panels sit overnight, because the smell isn't too pleasant.
Pics of the materials:
Starting door panel:
Door panel finished:
After I get everything finished I'll let you guys know how well this worked. I spent $40 in materials with tax, so it would be a pretty cheap solution to getting rid of some exterior road noise. Not the prettiest solution, but I feel it should help out greatly.
-Matt
9 Pages V   1 2 3 > »
Replies (1 - 19)
post Sep 13, 2008 - 11:55 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
I put the interior back in and put the car to the test on the highway. I must say that it's almost silent now. I will still have some slight noise though due to the lowering and my 17's. I would say that it's VERY MUCH worth the $40. I will be using what I have left to put under my carpet whenever I get brave enough to pull it out.
-Matt
post Sep 14, 2008 - 10:44 AM
sometimes cheap works better that expensive.
that foam absorbs the noise so well. Has anybody ever seen a quiet room? They use foam. I like that idea for my doors. will try it
post Sep 14, 2008 - 1:36 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE (njccmd2002 @ Sep 14, 2008 - 10:44 AM) *
It worked wonders on my panels. I also stuffed some in the paneling where the rear speakers go.
I'd like to put some under the carpet, how difficult is it to take out?
-Matt
post Sep 14, 2008 - 1:47 PM
3 hour job.
1.5 to take out and 1.5 to put in
have to take the center console out, etc ill be painting mine very soon
This post has been edited by njccmd2002: Sep 14, 2008 - 1:47 PM
post Sep 14, 2008 - 9:36 PM
D_Dawg
Joined Jul 22, '06
From San Antonio / georgetown, Texas
cool idea, ill prob give it a try in the summer. how heavy is the material?
post Sep 14, 2008 - 9:51 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE (D_Dawg @ Sep 14, 2008 - 9:36 PM) *
Not very, I'm sure overall it maybe added 6-7 lbs? The doors do feel slightly heavier.
post Sep 14, 2008 - 10:36 PM
CaliJeff
Joined Apr 22, '07
From Bay Area, California
did you dynamat the plastic/leather door covers before putting on the carpet stuff?
You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=-
post Sep 14, 2008 - 11:26 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE (CaliJeff @ Sep 14, 2008 - 10:36 PM) *
Yeah, but I did that nearly a year ago. It didn't do as well as I had hoped, but the padding FAR exceeded my expectations and I'd say it's better than Dynamat as well as more cost efficient.
post Sep 15, 2008 - 10:50 AM
itssteve
Joined Dec 14, '07
From yorktown Va.
well what most people dont understand is that the dynamat doesnt act as a noise barrior like the padding does, the mat is to weigh down the pannels so the speakers and bass do not flex the pannel and it helps reduce distortion flexing.
post Sep 15, 2008 - 10:29 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Aye: dampening = weight, to reduce resonance and sympathetic vibration. Insulation = absorption, to reduce transmission.
The one that's popular on Corvette forums, which I'll do once my Focal door speakers come in, is duct insulation. It's a foam backed by foil, self-adhering. The idea is that the road noise is absorbed through the foam, what makes it through the foam bounces off the foil and is further absorbed in the foam. Frost King/Thermwell is the usual brand, carried at Lowes and Home Depot.
http://mikemercury.home.att.net/sound.htm
post Sep 16, 2008 - 10:26 AM
CaliJeff
Joined Apr 22, '07
that sound dampening spray is similar to the stuff they use at thte dealership that they spray underneath the cars and wheel areas to reduce noise. There is a Dynamat brand to.
post Sep 17, 2008 - 8:34 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE (CaliJeff @ Sep 16, 2008 - 10:26 AM) *
Yeah my dad was telling me about underliner spray. I'd like to give that a try as well.
-Matt
post Sep 17, 2008 - 11:59 PM
dagreat1
Joined Mar 27, '06
From Gainesville
one of my celicas is corked dyno matted and foam insulated. Don't hear much road noise, but I still hear that 3sgte. As for my St I'm going to see what I can go with about $50 worth of foam and $50 worth of cork.... it should be silent
post Sep 18, 2008 - 6:32 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
I've seen that underliner spray - it's available at most auto supply stores actually. It's like a black rubberizing spray that you coat the undercarriage of your car with. Dealerships charge like a few hundred dollars for it, but it's really like ten bucks for a can of it. Only thing is, you have to get your car up on a lift if you can, so you can de-grease it thoroughly before you apply the spray. The spray will also protect against rust (good for those who live where it snows and the roads are salted)
Great job with that carpet padding! I bought some foil-backed insulation stuff to put down under my carpet, but I won't have enough for the doors so I think I'll do what you did and make a little visit to Home Depot! I'm on 17s (and will be lowered soon) and I HATE the road noise!!!
post Sep 19, 2008 - 10:14 AM
any updates on the carpet area. I have my carpet off and this is tempting me so much!!!!!
This post has been edited by njccmd2002: Sep 19, 2008 - 10:14 AM
post Sep 19, 2008 - 12:04 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
QUOTE (njccmd2002 @ Sep 19, 2008 - 10:14 AM) *
No, I'm just not going to do the carpet. I'm satisfied with how the other panels helped it, but I imagine the carpet would greatly help out as well.
-Matt
post Sep 19, 2008 - 12:05 PM
GriffGirl
Joined Feb 7, '07
Gosh, there's just all kinds of responses I can think of to that comment, but I'll keep them to myself since this is a "family" site. laugh.gif (talk about tempting though!)
Anyway I say do it! Get thee some carpet padding and line that b*tch! I'm stopping at HD tonight on my way home and doing it this weekend.
post Sep 19, 2008 - 1:29 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
I might do my carpeting on Sunday if I feel like ripping everything out.
post Sep 19, 2008 - 3:05 PM
QUOTE (GotToyota @ Sep 19, 2008 - 2:29 PM) *
well i might beat you to it.
9 Pages V   1 2 3 > »
Lo-Fi Version Time is now: December 11th, 2024 - 2:22 AM
