> Keep Blowin Out A/C Fuse!!!
post Oct 6, 2008 - 9:13 PM
Davesceli
Joined Apr 24, '04
From S. Cali
So basically my problem is that every time i try to turn my a/c, i blow out the 10A fuse in the fuse box, the one under the steering wheel.
Im guessing its a problem with the switch, but everytime it tries to engage the clutch on the compressor it blows out the whole climate control panel.
I thought i had a short somewhere in the cabin, but i couldn't find anything. Im all out of ideas...has anyone had this problem or know of any possible solutions??
Thanks
This post has been edited by Davesceli: Oct 7, 2008 - 12:48 AM
Replies (1 - 6)
post Oct 7, 2008 - 12:53 AM
Davesceli
Joined Apr 24, '04
From S. Cali
post Oct 7, 2008 - 8:40 AM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
Does the heat work? Fan blowing air?
If those work normally until you press the a/c button then odds are it's the clutch on the compressor.
post Oct 7, 2008 - 10:42 AM
Davesceli
Joined Apr 24, '04
From S. Cali
yea all that works...it only does it when i switch on the a/c. Is there anyway to check the clutch?
This post has been edited by Davesceli: Oct 7, 2008 - 10:54 AM
post Oct 7, 2008 - 1:59 PM
caszboy
Joined Jun 16, '08
From va beach
I'm having the same problem. I had my A/C system checked and discovered that my compressor was the problem. When its seized, the compressor draws to much amps and blows the fuse. So, that would be the first thing i would check. I still have not fixed mine and won't until next summer. The compressor cost $200-$500 and the expansion valve needs to be changed with it as well which is only $25.00. BUT the expansion valve is behind the dash which means TONS OF LABOR!!!!
Casey
post Oct 7, 2008 - 4:14 PM
CaliJeff
Joined Apr 22, '07
From Bay Area, California
i was looking on my car for the ac fuse but cant find it, what is it labeled as? CDS ?
You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=-
post Jun 24, 2012 - 2:16 AM
Samuel
Joined Jun 24, '12
From Texas
QUOTE (Davesceli @ Oct 6, 2008 - 10:13 PM) *
Thanks
My Celica is doing exactly what you described but how can I tell if the compressor is bad? Spent the entire day and half the night in the TX heat trying to figure this out! Any help would be greatly appreciated.
Lo-Fi Version Time is now: November 26th, 2024 - 8:36 PM
