> Subs in the trunk
post Oct 13, 2008 - 10:21 AM
mikecelica
Joined Jan 31, '07
From Ontario, Canada
Celica hatchbacks that have full size spare tires and have a big bulge in the middle of the trunk how do you put subs or anything in?
This post has been edited by mikecelica: Oct 13, 2008 - 11:41 AM
Replies (1 - 16)
post Oct 13, 2008 - 10:47 AM
chucho
Joined Mar 23, '03
From New Orleans
look for some free air subs and get small boxes. I have a coupe so I cant tell ya how much room you have. I'm in the process of getting some fiberglass boxes molded in the wheels of my coupe.
post Oct 13, 2008 - 5:59 PM
Promasta
Joined Oct 2, '07
From Manitoba, Canada
bassworx makes a hatchback box 2 10s or 2 12s it fits nicely between the backseat and the spare tire.
post Oct 13, 2008 - 7:11 PM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
get rid of all of it
BOOST GETS YOU LAID!!!!
post Oct 14, 2008 - 10:51 AM
Legit94GT
Joined Feb 6, '08
From Oregon
QUOTE (mikecelica @ Oct 13, 2008 - 10:21 AM) *
I have a coupe and have less room than you do frown.gif I was able to fit two 12" subs in one box back there with full access to the spare tire.
You can do it no problem. depending on how many subs and how big you want to go you can keep your full size spare.
1 JL 1,000/1v2
2 JL 12" W6v2
2 Focal 6.5 component 165a1
Kenwood DDX512 head unit
Running 142.6db with the back seat up:)
post Oct 14, 2008 - 4:37 PM
mikecelica
Joined Jan 31, '07
No the problem is that the bulge in the middle leavs barely any space on each corner, and I cant even fit one box between that and the back of the seat.
post Oct 15, 2008 - 1:07 AM
mitchy
Joined Jul 12, '08
From QLD, Australia
i was wondering this as well. surely someone must have kept their full size spare in the car and made a box.
post Oct 15, 2008 - 5:06 AM
WWSideWinder
Joined Oct 2, '08
From New Zealand
I have see one on the Russian Curren Club sight that I want to copy.
Looking for the site again..... :-(
http://curren-club.org/@/viewtopic.php?f=4...=a&start=10
I can't see where they extend to but I have a few inches from where his speakers are to the back of my Seats
so I'm going to have a look a fitting a sub there (Custom Build a Box)
cu
WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
~ signature made by jaws4god ~
Have a look at my thread for updates on my progress.
"http://www.6gc.net/forums/index.php?showtopic=63338&hl=0"
post Oct 15, 2008 - 8:32 AM
D-Man
Joined Jan 18, '08
From Houston
First, the full size spare was supposed to be a donut. the well is big enough for a full, (provided you dont have 20's or sometehing, lol.) The buldge is because of it being full sized.
As for fitting in subs... Well, i've got a vert (witch has the smallest of all trunk spaces mad.gif ) and you dont really access your spare w/o some re-arranging anymore frown.gif
Here is a pic of my trunk delete:
Damn D-Man - most impressive.
post Oct 15, 2008 - 11:11 AM
Legit94GT
Joined Feb 6, '08
From Oregon
QUOTE (mikecelica @ Oct 14, 2008 - 5:37 PM) *
My box sits on top of the bulge, and i do have to remove the box to get to the spare, it has been a few months since i've had to even look at that or think i about it so i couldnt remember when i left my first post. but as you can clearly see fromt he pic my box site on top of the bulge.
It could just be your box, like it being to big, but that all depends on your set up.
How many subs are you running and is it possible that you could do it with a smaller box?
1 JL 1,000/1v2
2 JL 12" W6v2
post Oct 15, 2008 - 5:20 PM
mikecelica
Joined Jan 31, '07
No i have a single 12" box. I think Im gonna just remove the spare tire and put a piece of wood to cover the hole. thanks for the input
post Oct 15, 2008 - 5:28 PM
Jaws4God
Joined Mar 27, '04
QUOTE (jesterwr217 @ Oct 14, 2008 - 1:11 AM) *
x 2
post Oct 15, 2008 - 5:30 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Why not build a box which fits around the hump? There's nothing to say a sub box has to be rectangular. In fact, curves produce more volume from the same area than do straight lines.
post Oct 15, 2008 - 5:33 PM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
My old sub box used to be triangular and it sounded awesome with 1 12" in it.
Use shallow mount subs like Kicker CompVT's. Their 12" sub has a mount depth of only 4 5/16", and can also be flush mounted against the back of a box. They even come with a metal plate so you can sink the sub into the backside of the box and put the metal plate on the backside of the magnet. I use one of these subs in a thin box and it sounds pretty good. I have plans to make a box that is similar in nature, but will house my bigger AVI SLS-300 sub on the right side and then be sunk in housing my amp, capacitor and crossover on the other side.
This post has been edited by Sinyk: Oct 15, 2008 - 5:33 PM
post Mar 30, 2009 - 4:44 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
I have 3 10's in the back of my hatchback. The box sits just on top of the spare and come to the top of teh back seat, its basically flush, I have the amp mounted to teh back of the box, and i still have trunk space. It does look a little goofy but i am planning to cover up the spare with a new floor board that i will make out of wood and cover with carpet once the weather gets nicer.
My Celica!
post Mar 30, 2009 - 6:13 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Unless you're running stock sized wheels there's really no point in even having the spare back there, I say get rid of it.
Unless you've got whatever the hell I've got in my trunk, which doesn't leave a bump in the middle at all. The carpet isn't molded for a bump, either. It just was never there.
Another solution would be to get shallow-depth subs, maybe they'll fit behind the bump. You could also consider getting a bazooka tube, they also take up way less room than standard subs.
post Apr 8, 2009 - 12:42 AM
jgutierrez
Joined Sep 16, '08
From Waco, Texas, USA
I have a hatchback and this was my question for some time, and then I decided to remove my spare and put a probox superbass 15 L7 inside, best sound setup I have made yet from trying and having 4 different sub boxes
Lo-Fi Version Time is now: November 27th, 2024 - 6:31 AM
