Engine slow?, i dont know... |
Oct 27, 2008 - 2:01 AM |
Enthusiast Joined Apr 29, '03 From lynn,ma Currently Offline Reputation: 0 (0%) |
I dont know if it's me but my engine seem to be getting weaker or something... it doesn't have the usual speed or pull it use to have. Any known problem that would cause this? My car is idling fine at 1k but it just lack any power when trying to put up speed.
Oct 27, 2008 - 7:55 AM |
Enthusiast Joined May 6, '08 From Lisarow, NSW, Australia Currently Offline Reputation: 0 (0%) |
lack of compression? might be something less serious but its probably just getting old, how many km on it?
Oct 27, 2008 - 9:36 AM |
Enthusiast Joined Apr 15, '07 From Fort Worth, TX Currently Offline Reputation: 12 (100%) |
Do a standard tune-up (plugs, wires, oil change) and see if it improves. Also, take off the negative battery terminal while doing all of that so you can reset your ECU.
-Matt |
Oct 27, 2008 - 11:05 PM |
Do a standard tune-up (plugs, wires, oil change) and see if it improves. Also, take off the negative battery terminal while doing all of that so you can reset your ECU. -Matt standard tuneup was performed during summer like 3-4months ago? actually.... maybe i should change the airfilter for my car.... okay, I'll do that to see if that helps... even though it doesn't seem like it's dirty ... |
Oct 28, 2008 - 12:32 AM |
could try but I can hardly see that doing anything, could try fuel filter maybe, I dunno? mechanic seems best bet.
Lo-Fi Version | Time is now: December 2nd, 2024 - 6:27 PM |
