> Key ring light is missing....., no lights...
post Oct 30, 2008 - 8:08 AM
bg_driver
Joined May 1, '08
From Cyprus
Hello
i have some problem with the light for the ignition key ring...
..i check that i on my wires i have 12v but still no light ,also check the bulb - it's ok... do you know wich part control this light?
I check all fuses but they are ok!!!
Thanks
This post has been edited by bg_driver: Oct 30, 2008 - 8:12 AM
Replies (1 - 3)
post Oct 31, 2008 - 6:51 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
the bulb could still be bad even if it looks ok. try a new bulb before you go ripping things apart trying to figure it out.
The light is controlled by the door/courtesy lights. It should come on when a door is opened and stay on for something like 10-20 sec after.
I <3 Dustin---07/16/06
post Nov 2, 2008 - 2:29 PM
bg_driver
Joined May 1, '08
From Cyprus
QUOTE (hurley97 @ Oct 31, 2008 - 7:51 PM) *
i try with ohters bulbs but it's dosn't work....
post Nov 2, 2008 - 4:51 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
bad wiring? test it with your friend the multi meter.
Lo-Fi Version Time is now: January 9th, 2025 - 5:53 PM
