> Grounding, Grouding Car
post Oct 30, 2008 - 5:40 PM
alaNi
Joined Nov 24, '06
From Kansas City
Where all should I ground to improve my electronic response?
Replies (1 - 5)
post Oct 30, 2008 - 5:48 PM
Chiefton
Joined Sep 14, '05
From London Baby
QUOTE (alaNi @ Oct 30, 2008 - 10:40 PM) *
boot or engine bay?
boot i had four rubber grommits which jus pop out (think tey may be drainage holes), then i found a suitable nut and bolt and connected a ring connector throw thta. Most important thing is to make sure the area is clean off paint, otherwise it wont be a proper ground. Usinsumtin solid, like a sflat ended screw driver to remove the paint.
Engine bay, i jus beefed up my original ground with sum 4 gauge
Source Unit: Panasonic CQ-TX5500W (Tubular)
Amplification: Genesis Dual Mono x5, Monoblock x1
Processing: Phoenix Gold DD10, Epicentre, UCS Pro, Brax Multicontrollers
Speakers: MB Quart QSD, Kenwood
Cables: KnuKonceptz, Phoenix Gold
Fabrication: Homebase Wood, Dynamat, Old Foam
post Oct 30, 2008 - 9:13 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
eletronic response to what? If your talking about the engine bay there is the big three. Pretty simple though. Check this out.. Or I suppose you can redo your whole grounding setup with some bigger gauge wire.
post Jan 3, 2009 - 1:10 PM
what about this....
http://cgi.ebay.com/ebaymotors/TOYOTA-CELI...%3A1|240%3A1318
post Jan 3, 2009 - 1:15 PM
Lil-Joe101
Joined Dec 7, '07
From Corpus Christi, TX
Im grounded like this, if it helps u out.
Replaced both ground wires at the battery, one at the tranny. I put one on the intake manifold, one on the altenator and one on the head.
post Jan 3, 2009 - 3:29 PM
WWSideWinder
Joined Oct 2, '08
From New Zealand
Updated my Wiering.
Changed the Cable from Cylinder Cover to Ground as wellas running a new cable (8 guage) to my "Ground distrubiter"
Changed my Factory main cable (Battery to Starter) with 4 guage cable
Added the "Ground Distrubiter" for all my outher ground wires (8 guage)
I have a 4gauge wire + Fuse (red) for my Amp
I still have to run a 4 guage wire from my Alternator to the battery.
Thewe are many ways to do this as some people like the factory look and have stelthed there instalations, I have gom for a color code (Red for + and Blue for -) but doo wat ever you like the only think with this is check your connections are good ones or you will have problems. biggrin.gif
WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
~ signature made by jaws4god ~
Have a look at my thread for updates on my progress.
"http://www.6gc.net/forums/index.php?showtopic=63338&hl=0"
Lo-Fi Version Time is now: November 30th, 2024 - 5:33 AM
