Quick airbag question referring to the ECU |
Nov 13, 2008 - 3:00 PM |
Enthusiast Joined Feb 20, '08 From Abingdon, Maryland Currently Offline Reputation: 7 (100%) |
okay, so i've had these new airbags sitting around forever and i'm finally going to put them in. I have both airbags and the front 2 senors, however.... do i have to replace the ECU as well? I've heard that you do, and i've heard that you don't have to....
can i just reset it like this (thread link for pic below) and get away without buying a new ecu? or do i have to replace it? and when people say "center sensor" and "main control module", they are referring to the ECU, correct? |
Nov 14, 2008 - 12:12 AM |
1 replace, no you don't have to.
2 yes. The center sensor and main control module is the SRS ECU. Try clearing the code (it's tricky to do but it does work) -------------------- |
Lo-Fi Version | Time is now: January 11th, 2025 - 3:03 PM |
