> question on front strut bar
post Dec 4, 2008 - 3:29 PM
Toyota_Celica_97
Joined Sep 25, '08
From california
hi everyone i have an question on how to install the front strut bar.
do i need to jack the car up? and do the the wheel and all those other stuff need to come off? cause i got an c-one front bar with 3pts, i heard that if i took off all 3 screw the wheel and other stuff on it might fall off.
like help.
of a step by step on how to do it will helps alot.
P.s. : i already try the search thing and there not much of a use info on this.
Replies (1 - 8)
post Dec 4, 2008 - 3:45 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Step 1- pop your hood.
step 2- look at the strut tower, you'll see 3 nuts on both sides of the towers. They are near the fenders and fire wall. You'll see them. Remove the 6 nuts assuming you don't have a factory strut bar.
step 3- If you do have a factory strut bar you will see 2 bolts in the center of the engine bay on the firewall bolting down the factory strut bar. Remove those 2 bolts.
Step 4- put on your 3 point and bolt down the nuts and apply the 2 center bolts for the center part of the strut bar onto the firewall.
94 Celica gt white (sold)
post Dec 4, 2008 - 4:00 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
I thought you WERE supposed to jack the car up to take the load off the struts before you put the strut bar on, so that it goes on with "equal distribution" on both sides (for lack of a better word)
post Dec 4, 2008 - 4:10 PM
Toyota_Celica_97
Joined Sep 25, '08
From california
thanks bccentaur3, you forgot step 0 : unlock my hood first lol.
and grifffirl i not quite sure what you trying to say =/
post Dec 4, 2008 - 4:51 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Griff I guess you're right. I never thought of that. Either way, I guess I have been doing it wrong the whole time. Oh well, my car still handles like a go kart.
post Dec 4, 2008 - 4:55 PM
95st-celica
Joined Mar 29, '07
From Philly
i dont think it matters to be honest...i never jacked my car up either...it just creats the car from swaying...its not going to add any rigidity to it just by jacking it up and putting it on i dont think...as long as its on its on lol
1988 Dodge Aries K (sold)
post Dec 4, 2008 - 6:02 PM
azian_advanced
Joined Apr 18, '05
From Calgary
You don't really need to jack up the car, you would only need to if the weight of the car is putting too much compression to remove the factory strut bar or if there is too much compression to install the new one. Seeing that you got a C-ONE strut bar, I'm sure it will be a tight fit if you don't jack the car up. Fitting my Apex'i one is always a tight fit if I don't jack the car.
post Dec 4, 2008 - 6:44 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
I fitted my J-Speed and it went on like buttah.
post Dec 4, 2008 - 7:00 PM
96bluevert
Joined Mar 19, '07
From Washington
Yeah I didn't jack up my car either and the strut bar went on fine.
Lo-Fi Version Time is now: November 23rd, 2024 - 3:34 PM
