> i need serious help!!!, i hate idiots
post Dec 11, 2008 - 9:17 PM
celica09
Joined Nov 17, '08
From columbia al
ok so i had my celi under my gfs carport and i was getting ready to pull the engine no hood on it or nothin no front bumper and a huge hole in the windshield well we had a huge storm come threw these last 2 days and i went over there today to check on it and one of her stupid *** brothers friends pulled out my ****ing car and left it in the rain and then the stupid *** thought he could b funny and pull my ****ing spark plug wires and let it sit out there in a freaking huge *** storm so now i got most of the water out of it that i saw but wat should i do i know the last thing i need to do is try and start it but wats a good few tips to try and make sure i dont mess nothin up more than it already is
thanks in advance guys
Replies (1 - 6)
post Dec 11, 2008 - 9:49 PM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
wtf.
id ki...
This post has been edited by terbear4god4life: Dec 11, 2008 - 9:49 PM
"she can polish my strut bar anytime As long as her blow-off valve's in good order"
post Dec 11, 2008 - 9:53 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
I say beat that kid down for messing with your property. I don't know if changing your oil helps.
94 Celica gt white (sold)
post Dec 11, 2008 - 10:01 PM
celica09
Joined Nov 17, '08
From columbia al
so far i called up some ppl they said to see if the spark plugs help the water out of the block and get all the water out and try to take off the head before it leaks into it leaks onto the rods pistons and crank and to drain my oil just in case and then wen everything is drained and replaced to then try to start it after i get new oil and stuff i hope it works and yeah i got a hold of him but i cant say wat i did cuz that would b a confession :]
post Dec 12, 2008 - 11:48 AM
to be 100% safe, pull engine and tear down, make sure its clean.
post Dec 12, 2008 - 9:36 PM
change oil
spray some starting fluid in the cylinders
crank the engine with no plugs and fuel pump fuse out
repeat steps 2 and 3 a few more times
put plugs in
put fuel pump fuse in
start engine
post Dec 12, 2008 - 10:00 PM
macavely
Joined Nov 4, '02
if I was in your shoes. this is what I would do (put this is just my way of thinking) . take this as an opportunity to rebuild your engine. tare that bad boy down. hang all parts over night and let them drip dry. oil and water should drip off after a day. clean all parts and check for damage and replace everything that needs to be replaced or that you want to replace just cause you can at this point.
but if you don't want to do that. do what the person above me said
Lo-Fi Version Time is now: November 23rd, 2024 - 8:41 PM
