> Antenna issues
post Dec 12, 2008 - 12:42 PM
aggieanton
Joined Dec 16, '07
From College Station, TX
Hey guys, my power antenna is going out... again. I have no idea what the problem is, but the antenna motor keeps running after the antenna has gone all the way up. Is there a cut-off switch that is supposed to stop the motor when it reaches the top? This thing started gradually... at first it would only run a few seconds after the motor hits the full antenna extension - now it runs for about 20 seconds and seems to be running longer each time i start the car. Has anyone had this issue before? I took the antenna assembly apart thinking the gears were stripped, but everything looks fine.
Are there non-power antenna options available for the 6g celica?
Replies (1 - 4)
post Dec 12, 2008 - 3:16 PM
Legit94GT
Joined Feb 6, '08
From Oregon
QUOTE (aggieanton @ Dec 12, 2008 - 12:42 PM) *
Yup, i'd say go with the S2000 antenna. If you cant find that parts in a junk yard you will have to go to the dealerships which will cost you... When I did my swith i had to buy both parts through dealers and some other random parts everything ran me around 60 or 70 bucks... I wrote a hunge HOW TO on doing the switch with lots of pics...
1 JL 1,000/1v2
2 JL 12" W6v2
2 Focal 6.5 component 165a1
Kenwood DDX512 head unit
Running 142.6db with the back seat up:)
post Dec 15, 2008 - 4:45 PM
96bluevert
Joined Mar 19, '07
From Washington
How much do you use the radio? What I did was just disconnect the motor b/c I never listen to radio and I was tired of it going up everytime I turned my stereo on. Not sure if it's the same for hatchbacks, but for coupes/verts, there is a side panel inside the trunk with a little door on it and the connector is right behind that.
Or you could go S2k antenna which is a pretty nice choice also.
post Dec 15, 2008 - 5:46 PM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
^ That. Screw radio, and CD's for that matter, I only use my iPod. biggrin.gif
post Dec 23, 2008 - 1:31 PM
the mast rail is broke. you have to replace the mast. but first open the motor to get the broken piece of rail out. Or go aftermarket
Lo-Fi Version Time is now: June 10th, 2026 - 2:46 AM
