> 2nd Gen MR2 full clip conversion
post Oct 3, 2003 - 3:23 PM
TheWackySquirl
Joined Oct 3, '03
From Myrtle Beach
I have the full rear clip now what else will i need?
Replies (1 - 5)
post Oct 3, 2003 - 3:29 PM
Guest_Matthew_*
umm if you dont know what you need you are in more trouble than you think
you have to tell us everything that you have first off
also you need someone to do your wiring harness
IM Qatar11 on aol instant messenger
that will be like 500 bucks
you should've got the 90-93 GT-Four Clip (st185) its way easier and more people can help you do it since thats the most popular swap
also usually has less mileage
post Oct 3, 2003 - 3:44 PM
Kwanza
Joined Apr 8, '03
From NorCal
QUOTE (TheWackySquirl @ Oct 3, 2003 - 1:23 PM)
Shift linkages (if you don't have a GT), various mounts for A/C, PS, Radiator, etc... There will be a lot more parts to source... I don't know exactly what...
post Oct 4, 2003 - 4:21 PM
TheWackySquirl
Joined Oct 3, '03
From Myrtle Beach
I have a full rear clip for a 2nd gen MR2 wiring harness ECU trans and axels do i need a new intake manifold sence the original from the mr2 comes back over the valve cover. I want to do a frount mount intercooler not a top mount. What mounts are needed.
post Oct 4, 2003 - 4:29 PM
Guest_Matthew_*
you'll have do to custom piping and mounts and everything since no one makes a fmic for the celica.
as far as i could guess you can use the stock intake manifold
and about the wiring harness you have to get your stock one from your 5s-fe and the 3s-gte done up or w/e you want to call it because the 3s-gte harness will not work with your celica persay. you have to have it elongated or something.. honestly i really dont know what he does but if you ask Mike (aim Qatar11) he will tell you
post Oct 5, 2003 - 2:20 PM
95ST
Joined Jan 1, '03
From CT
are there any after market intake manifolds for the 3sgte? or would you have to have one custom made?
Lo-Fi Version Time is now: February 25th, 2025 - 10:58 AM
