Got my GT4 Clear Signal Lenses! WOOO! |
Dec 26, 2008 - 7:10 PM |
Enthusiast Joined Mar 20, '07 From Bakersfield, CA Currently Offline Reputation: 10 (100%) |
But now I ask what is the best method for removing my old lenses? Can I put them on a cookie sheet? Or would that melt the original housing? I guess what I am asking is what is best used to place objects of your car (Turn Signals. Projectors, etc..) to be sat upon in the oven?
-------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Dec 26, 2008 - 7:37 PM |
-preheat oven to 250
-bake on a cookie sheet for about 10mins (one lens/housing at a time) -then carefully pry the old lens off *if the lens doen't wanna come off, stick it back in the oven *kinda play around with the bake times -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Dec 26, 2008 - 7:44 PM |
-preheat oven to 250 -bake on a cookie sheet for about 10mins (one lens/housing at a time) -then carefully pry the old lens off *if the lens doen't wanna come off, stick it back in the oven *kinda play around with the bake times Oh ok. The sheet won't melt the housing? -------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Dec 26, 2008 - 7:48 PM |
it didnt when i did my custom job.
you can try baking at a lower temp and shorter time if your not sure, but with more trys ***try baking @ 200 for 5 mins and re-bake if the lens is still hard to come off This post has been edited by 808celica: Dec 26, 2008 - 7:49 PM -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Dec 26, 2008 - 7:58 PM |
it didnt when i did my custom job. you can try baking at a lower temp and shorter time if your not sure, but with more trys ***try baking @ 200 for 5 mins and re-bake if the lens is still hard to come off K. I gotta wait til Monday though. Now I just need to know where I can find a Chrome can of spray paint for the inside of the housing so the light reflects better. Just a suggestion that Richard (Wolfie308) made that sounds good to me. -------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Dec 26, 2008 - 9:57 PM |
I wouldn't use the oven, it's easy to warp the platic housings. Try boiling them first. It will soften the glue holding the lenses in and not damage the housings.
Dec 27, 2008 - 1:10 AM |
Enthusiast Joined Sep 17, '05 From Newcastle / UK Currently Offline Reputation: 4 (100%) |
I was wary about using the oven for fear that it would destroy the housings, but in the end went with setting the oven on its lowest setting and trying for a few minutes at a time until the glue became plyable. Id recccomend some type of glove when handleing the units when they come out of the oven
-------------------- 1994 JDM GT4 WRC
Dec 27, 2008 - 2:42 AM |
I wouldn't use the oven, it's easy to warp the platic housings. Try boiling them first. It will soften the glue holding the lenses in and not damage the housings. Thanks Batman! I am asking for both turn signals and projectors...... I am rather scared to use that oven. I do not have a pot big enough for the projectors, although I would be less scared to do that with projectors than the turn signals... I might just end up boiling them like you said. I dunno yet. I got until Monday to think it through. -------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Dec 27, 2008 - 2:52 AM |
works great with lows and highs -------------------- |
Dec 27, 2008 - 6:04 AM |
Enthusiast Joined Nov 21, '05 From England Currently Offline Reputation: 6 (100%) |
I have to say my preferred method is the oven, which I use for much more complicated dismantling than these.
Place the units on an oven glove not the shelf direct and 5-10 mins at 100 deg C should be fine. Take the time to poke the mastic back into the recess when you've got the ambers out. Regards the 'silver' spray, look for some thing 'chrome' or 'bright metallic' which has more of a mirror finish if well sprayed. With the GT4 turns, I've found it nicely smooths the look if you remove the uneccessary partition inside(not possible on the ST202 units). Pic below shows what I mean.... and when fitted on your car they should like this(until you respray it)...... Look forward to pics -------------------- Has your car ever been on T.V? Mine was used in the opening sequences here - note the clear turns and front LED's
http://videos.streetfire.net/video/Wheeler...11-9c0f00a0b820 |
Dec 27, 2008 - 7:20 AM |
this thread is making me hungry
Dec 27, 2008 - 10:56 AM |
Enthusiast Joined Jun 21, '08 From Naples, FL Currently Offline Reputation: 0 (0%) |
WTH? And I always thought they were direct replacements, not that you just replaced a lens...weird.
Dec 27, 2008 - 11:10 AM |
I thought everybody realised it was the lenses only I make.....
and the ST202..... Hope that errr....clarifies -------------------- Has your car ever been on T.V? Mine was used in the opening sequences here - note the clear turns and front LED's
Dec 27, 2008 - 1:28 PM |
I cant reccomend these enough, the quality and finish is OEM all the way
Dec 27, 2008 - 1:43 PM |
Yeah Richard makes bad ass lenses! Look at the numbers and Toyota logo on those bad boys! Tell me the man didn't do such a great job on making those look OEM? I can't wait to put them on, and yes, there will be pics. I just gotta go and pick up some paint and such. I bought these LED lights that I guess came from Japan. I made the mistake of getting some other LED lights that didn't fit in the GT4 turn signal housing. But PolyLED on EBAy is who I bought these from. Didn't think I would dish out $29.99, but there are nothing like them online. They were made to fit.
Pay no mind to those green leaves, stems, and seeds you may see in the photo. This post has been edited by Random_Stranger: Dec 27, 2008 - 1:50 PM -------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Dec 27, 2008 - 7:26 PM |
Enthusiast Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) |
Pay no mind to those green leaves, stems, and seeds you may see in the photo. Ah, I see you are a green tea connaisseur also -------------------- Davey
Items for sale |
Dec 27, 2008 - 9:07 PM |
Enthusiast Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) |
Yeah Richard makes bad ass lenses! Look at the numbers and Toyota logo on those bad boys! Tell me the man didn't do such a great job on making those look OEM? I can't wait to put them on, and yes, there will be pics. I just gotta go and pick up some paint and such. I bought these LED lights that I guess came from Japan. I made the mistake of getting some other LED lights that didn't fit in the GT4 turn signal housing. But PolyLED on EBAy is who I bought these from. Didn't think I would dish out $29.99, but there are nothing like them online. They were made to fit. Pay no mind to those green leaves, stems, and seeds you may see in the photo. no he was making pasta and seemed to have stilled some oregano.. this should look badass when its done!!! -------------------- BANNED. for life, you moron.
Dec 27, 2008 - 10:16 PM |
Jan 3, 2009 - 10:20 PM |
Enthusiast Joined Feb 20, '04 From Washington Currently Offline Reputation: 0 (0%) |
wow! thats a crap load of work! Got a question... where did you get the turnsignals from?? I just got the c-one front bumper and none of the turn signals fit! Do I have to get the GT-4 Signals??? I'm so confused about this!!
Jan 6, 2009 - 2:30 PM |
Enthusiast Joined Sep 27, '02 From UK Currently Offline Reputation: 1 (100%) |
Front Indicator Lense Replacement
Just removed my lenses, this is what I did: 1. Got large saucepan filled with water. 2. Placed on stove and pre-heated water until boiling. 3. Placed the indicator unit into boiling water sideways first so that there was boiling water inside the indicator unit and then up-ended it. 4. Left in the boiling water for about 5-7minutes (one took 5mins, the other took 7mins). 5. Carefully removed indicator unit (it's hot) and prised indicator lense off using a flat blade screwdriver. Next tasks... I have just bought some Chrome paint and propose to paint the interior of the light unit. This should produce an excellent reflective backing. Got some black paint in the garage so I'm going to accent the clear lenses. Then it's a case of fitting the clear lenses - I propose to do this by placing the indicator unit under the grill face-up so that the black putty/glue is pliable before slipping the new lense into place. This post has been edited by 3TST: Jan 16, 2009 - 10:09 AM |
Lo-Fi Version | Time is now: November 24th, 2024 - 9:29 PM |
