> Jumped the car backwards. HELP!, i did something pretty stupid.
post Dec 31, 2008 - 7:16 AM
OregonBoy
Joined Dec 31, '08
From Portland, Oregon
Hey 6gc members i was hoping maybe you guys could help me with this one.
soo a couple of days ago i...did the stupidest thing a car owner could do. i jumped my car with the cables backwards. AH. ****. I know it was stupid.
i read online that i would have to change the 100amp fuse, and i did. It seemed like that was the only one that had blown?
can anyone give like.. a diagnosis of what i need to do to get my baby running again?
Replies (1 - 10)
post Dec 31, 2008 - 7:50 AM
if its RHD no problem!!
LOL, please state what happens when you crank?
post Dec 31, 2008 - 7:57 AM
OregonBoy
Joined Dec 31, '08
it tries to crank over but it just wont. when i put the key in the lights next to the gauge all light up. My radio doesnt even turn on.
post Dec 31, 2008 - 8:22 AM
i would start to check fuses first. also get a multimeter and check battery juice.
post Dec 31, 2008 - 1:46 PM
JDM_Factory
Joined Mar 27, '08
From Fort Worth, TX
check all your fuse and amp from the engine bay and under your kick panel.
post Dec 31, 2008 - 5:49 PM
OregonBoy
Joined Dec 31, '08
thanks guys.
if the fuses blown that means nothing is really damaged than?
post Jan 1, 2009 - 3:02 PM
CelicaST_CALI
Joined Feb 28, '07
No you just replace the fuses and you should be good to go..
BANNED. for life, you moron.
post Jan 10, 2009 - 10:23 PM
f1yen
Joined Oct 29, '05
From Muskego, WI
Reverse termination can really screw up the battery too, well.... u were jumping it... probably bad neways. lol Just start pullin and replacing all the fuses u see
Remember proper way to jump a battery...
:::connect red on positive of good car, connect other red on positive on dead car. Connect black on negative on good car, then finally connect the other black one on a ground of the dead car, preferably the engine (NOT THE NEG BATTERY POST on the dead battery):::
if you dont belive me, i used to work for a car battery company, if your levels are low, the immediate voltage will jump the straps and create an explosion.
post Jan 10, 2009 - 10:46 PM
bseaman_5
Joined Apr 6, '08
From Overland Park
I had a similar situation like this and blew a fuse actually might have been 2 or 3, one of the fuses was something like A1 or something like that under the hood in the fuse box. I had no power at all, no crank, no dash, charged it over night and nothing. I figured out that the main power fuse had blown and had to bend the pieces back together to get to an autoparts store cost me like 2 bucks to fix the entire problem. Took me a while to be able to diagnose the problem and a few posts on here.
post Jan 10, 2009 - 11:11 PM
Cutrara
Joined May 6, '05
From PA
I was in a similar situation... I reversed the cables one time while jumping my car with a friends car. The battery light came on in my friends car, but there was no damage to either vehicle?
post Jan 12, 2009 - 1:25 PM
GriffGirl
Joined Feb 7, '07
Did you get it figured out?
Lo-Fi Version Time is now: February 25th, 2025 - 4:15 PM
