Drivers Side Speakers |
Jan 15, 2009 - 8:13 PM |
Enthusiast Joined Jan 13, '09 From Maryland Currently Offline Reputation: 0 (0%) |
My drivers side front speakers are out and i cant figure out why. I unplugged them and plugged them back in to check to see if it was a bad connection. That didnt work . Could anyone help me?
Jan 16, 2009 - 12:32 AM |
Probably a blown speaker. My car came with a blown driver's side speaker, and it didn't even try to work. I have a factory amp, and even still, when I pulled the speaker out, it was very clearly labeled on the back "TOYOTA 15 watt max." So if you've got an aftermarket head unit and you've cranked it up, it's a pretty safe bet that you fried your speaker.
Jan 18, 2009 - 10:26 PM |
Enthusiast Joined Nov 6, '08 From locust grove, va Currently Offline Reputation: 0 (0%) |
when i bought my car, i had the exact same problem. i had a bad factory stereo and replaced it with an aftermarket one and works fine now. good luck.
Feb 9, 2009 - 6:06 PM |
Enthusiast Joined Jul 24, '08 From Canoga Park CA. Currently Offline Reputation: 0 (0%) |
I am still browsing for answers but I stumbled on to this post . I have a front passenger 8 inch speaker out and I was wondering what kind is it. Also what kind will replace it. Where did you get it (I cannot find one anywhere)and what size did you use. Thanks anyways found that guide to use the old speaker as a adapter. Thanks for that one.
Rv Thanks in advance. 97 celica gt This post has been edited by xrav22: Feb 9, 2009 - 6:43 PM |
Lo-Fi Version | Time is now: December 1st, 2024 - 8:54 PM |
