> decisions,decisions...
post Jan 20, 2009 - 12:19 AM
relyks95gt
Joined Sep 29, '08
From miami
boost my 5s-fe or swap 3s-gte. there both ganna cost around the same.i need some help, what do you guys think?
-RELYKS
Replies (1 - 9)
post Jan 20, 2009 - 7:34 AM
relyks95gt
Joined Sep 29, '08
From miami
found the 3s for 1450 ****in preety awsome
-RELYKS
post Jan 20, 2009 - 7:55 AM
QUOTE (relyks95gt @ Jan 20, 2009 - 7:34 AM) *
and what does that get you exactly?
i would doubt you will get EVERYTHING you need for 1450.
and if you did, i wouldnt expect it to be in "drop in" condition.
if you think your doing a swap for 1500$, your sadly mistaken.
post Jan 20, 2009 - 8:11 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Do you want to tune the car and squeeze every bit out of it? Or do you want something to run like factory and go fairly fast? If you want to first then do the 5s turbo. If you want factory and fast do the 3sgte. Advantage of the 3sgte no need to tune. Advantage of the 5s turbo very torquey bottom end power.
I have had both and if I were to do it all over again I would have done the 5s turbo right with a some what built 5s. I was sick of tuning and figured the 3s swap would be easier, later on finding out you are soo limited with the factory computer. If you like tinkering around with your car do the 5s turbo. besides with the 5s turbo you don't have to yank your motor out, unless you plan on doing maintenance.
94 Celica gt white (sold)
post Jan 20, 2009 - 9:16 AM
_Jim_
Joined Sep 22, '08
From Bergenfield
5SFTE FTW below 300WHP
GEN3 3SGTE FTW above 300whp
330whp 309ft/lbs @ 21 PSI
post Jan 20, 2009 - 11:28 AM
95st-celica
Joined Mar 29, '07
From Philly
if you have a good 3k saved up...do the 3s swap...so much more potential and more power...plus you have a gt already which makes the swap that much easier...your gonna be doing an equal amount of work turboing that 5s then you would droping in a new motor.
1988 Dodge Aries K (sold)
post Jan 20, 2009 - 11:54 AM
relyks95gt
Joined Sep 29, '08
From miami
thats exactly what i was thinking cuz i already got 170,000 miles on it
-RELYKS
post Jan 20, 2009 - 1:16 PM
Trying to boost a motor with 170,000 miles is a bad idea.
Trying to do a swap on a $1,500 budget is also a bad idea.
post Jan 22, 2009 - 12:06 PM
nik
Joined Sep 30, '02
you want alot of power for cheap
sell your car and buy a modded car that already has a 3sgte
or you can buy my car with a 7agte built motor over 382 WHP
http://www.6gc.net/forums/index.php?showtopic=51291
post Jan 23, 2009 - 12:25 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
If you car was here, I would buy it from you RIGHT NOW. It's not fair that all the good deals are far away from me, LOL.
Lo-Fi Version Time is now: November 24th, 2024 - 2:23 PM
