> water pump
post Feb 5, 2009 - 1:16 PM
Timeless
Joined Mar 29, '08
From Montserrat
can a rav4 water pump work on a celica?
Replies (1 - 7)
post Feb 5, 2009 - 1:25 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
are the engines the same?
post Feb 5, 2009 - 5:55 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
It's not advised to use a USED waterpump.
post Feb 7, 2009 - 12:46 AM
6strngs
Joined May 12, '06
From Wilmington, NC
if going through all the trouble of replacing a water pump, might as well replace it with a new one so you don't have to do it again. I just pulled my water pump out tonght actually... you might as well change the timing belt too since it needs to come off to replace the water pump.
btw, a new water pump from 1sttoyotaparts.com is only like $80. Part number: 16100-79185
post Feb 10, 2009 - 7:57 PM
Timeless
Joined Mar 29, '08
From Montserrat
One thing though the water pumps on that site can fit my engine 3SGE ST202-0049145 2.0liter? because ive been having problems finding water pumps for my 3SGE engine
post Feb 10, 2009 - 11:11 PM
6strngs
Joined May 12, '06
From Wilmington, NC
Oh, didn't know you had a 3sge. The part number for the 3sge is: 16100-79225 (I checked, it's the same part number whether it's JDM or euro-spec)
post Feb 11, 2009 - 7:51 AM
Timeless
Joined Mar 29, '08
From Montserrat
i tried that part number and the part cant be found. I dont mean to be a hassle but my cars water leaks when i have come to a complete stop and shut off the engine does that mean its jus a seal thats gone bad or its the whole water pump?
post Feb 11, 2009 - 10:08 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE (Timeless @ Feb 11, 2009 - 4:51 AM) *
could be anywhere. you'd have to pinpoint exactly where it was leaking from, or at least the general vicinity so you know what to look for.
if you do end up needing the pump, take that part number to your local toyota dealership and they should be able to get it.
Lo-Fi Version Time is now: November 23rd, 2024 - 1:26 PM
