> Error code 23, I have an error code 23 on my st205 ECU
post Feb 9, 2009 - 1:58 PM
Stefan84
Joined Feb 9, '09
From Denmark
I have swapped a gen. 3 3S-GTE into my ST182 celica. I have an original st205 ECU but i have the following error codes:
21 which is the oxygen sensor
54 of course (i do not have the water to air intercooler)
My problem is the error code 23 because i do not know what the error is.
Does anyone know what error code 23 is???
I was told that it could be Intake Air Temperature Sensor signal, but i have checked the sensors and the wiring and i can't see any errors.
Replies (1 - 5)
post Feb 9, 2009 - 7:56 PM
silver6gc
Joined Aug 10, '08
From Raleigh, NC
I believe 23 is either Intake Air Temp sensor or the MAP sensor, if i remember correctly.
Trust me, I do this every day
post Feb 10, 2009 - 4:02 AM
Stefan84
Joined Feb 9, '09
From Denmark
hmmm ok, i have changed the MAP sensor because the one i got was wrong, but i got an error code 31 for the mapsensor and the map sensor i use now is from a running st205.
post Feb 10, 2009 - 11:51 AM
silver6gc
Joined Aug 10, '08
From Raleigh, NC
I was wrong, 24 is for the Intake Air Temp sensor, at least on USDM cars it is.
This post has been edited by silver6gc: Feb 10, 2009 - 4:32 PM
post Apr 19, 2009 - 11:26 AM
domyz
Joined Jul 29, '07
From Quebec, Canada
Did you figure what was the code 23 on rev 3 ECU???
post Apr 19, 2009 - 11:28 AM
http://www.gtfours.co.uk/default.htm?http%...ow_to/dv/dv.htm
A sensor is mounted in the inlet manifold to measure the temperature of incoming air, (205 only). Sensor measures the temperature of the incoming air so that the ECU can alter ignition and fuelling to suit. Colder air = more fuel
Lo-Fi Version Time is now: November 24th, 2024 - 12:47 AM
