> FS: Parting Out 5SFE engine, CHEAP PARTS! everything must go!
post Feb 21, 2009 - 3:35 AM
6strngs
Joined May 12, '06
From Wilmington, NC
Title says it all. I have a blown 5sfe that I'm parting out. The bottom end is blown due to metal shards getting into it and chewing up the pistons and cylinder walls. It's probably still rebuildable since the gouges weren't that deep, you'd just have to go with .020 or .040 oversize pistons ande overbore it. I'll let the bottom end go for cheap. The top end is still in good shape. Though I'd recommend rebuilding it before using it since it's got 162K on it. I have manifolds, etc. let me know what you need and I'll let you know what I've got.
At this time, I'm just selling the engine parts. I may have some other parts that I need to get rid of too. if I do, I'll post them here. Here's just a few of the parts:
5sfe intake manifold
5sfe stock exhaust manifold w/ heat sheilds
5sfe bottom end, block, crank, pistons, rods - $20 picked up, expect a high-ish shipping charge
5sfe head worked good on my car, has 162K on it. no cams. $35 + ship!!!
stock alternator, dirty but works good
brackets, for PS pump, Alternator, passenger side axle, etc.
valve cover, good condition, not painted
OBD1 (94-95) Manual transmission wiring harnesses. I have one california spec, and one federal spec. both are 98% complete. AFAIK they are both only missing one connector each. they may also be missing the rubber boot where it goes into the firewall. $50 each + shipping
Make an offer on anything! I'll let stuff go cheap to clear my garage. I especially want the engine itself out. Let me know what you need, I've most likely got it if it relates to the engine.
This post has been edited by 6strngs: Mar 10, 2009 - 8:38 PM
Replies (1 - 13)
post Feb 21, 2009 - 7:12 PM
94celicadude
Joined Mar 28, '04
From St.Louis
how much would you want for cams? and what year is the motor/car?
1994 GT Hatchback
1994 ST Coupe
1988 Corolla Wagon All-Trac
1999 Corvette
2008 Cobalt SS Turbo
post Feb 21, 2009 - 8:06 PM
6strngs
Joined May 12, '06
From Wilmington, NC
The engine is from a 94 california spec. Most parts are the same between the cali and federal spec though. For the cams, I was thinking somewhere around $150 + shipping. I'll take the best offer though. Though I'd prefer to get rid of them at the same time as the head.
post Feb 24, 2009 - 11:00 AM
6strngs
Joined May 12, '06
From Wilmington, NC
first post updated with a couple parts. That's not all that I have though, PM me for anything else you might need. though I don't have any power steering or A/C related components.
post Mar 10, 2009 - 8:39 PM
6strngs
Joined May 12, '06
From Wilmington, NC
cams sold!!!
Make me an offer on anything!!!
post Mar 16, 2009 - 9:11 PM
6strngs
Joined May 12, '06
From Wilmington, NC
bump
post Mar 16, 2009 - 9:22 PM
92-gt
Joined Jan 22, '09
From Bremen
Do you have a starter? If so, hoe much??
post Mar 17, 2009 - 1:31 AM
6strngs
Joined May 12, '06
From Wilmington, NC
sorry, don't have a starter that works
post Mar 17, 2009 - 2:49 AM
AzNbOiFrM9i6
Joined Feb 7, '08
From Antelope, California
what kinda intake you have?
post Mar 17, 2009 - 9:21 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
do you have a BVSV?
-Alex {](O_o)[}
post Mar 17, 2009 - 12:19 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE (AzNbOiFrM9i6 @ Mar 17, 2009 - 12:49 AM) *
only intake I have for sale is one for a turbo 5sfte/3rd gen 3sgte set-up.
do you have a BVSV?
If only I knew what that stood for... something vacuum switching valve? if so then probably, let me know what you need. I have a couple
post Mar 17, 2009 - 1:25 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
it's that blueish/green thing on the far right of the water neck. it's got like two nipples or whatever coming out of it.
-Alex {](O_o)[}
post Mar 17, 2009 - 4:30 PM
azn87
Joined Aug 2, '06
From bay area
do u have the dp with the cat on it? for lewfx
This post has been edited by azn87: Mar 17, 2009 - 4:34 PM
post Mar 17, 2009 - 9:31 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE (NgoFcukinWay @ Mar 17, 2009 - 11:25 AM) *
yep I've got that. How bout the whole water neck for $10 + $5 for shipping?
I have the manifold with the primary cat, not the front exhaust pipe with the secondary cat. Not sure which he is looking for.
Lo-Fi Version Time is now: December 2nd, 2024 - 11:55 AM
