Gauges not working!, :[ |
Mar 31, 2009 - 7:14 PM |
Enthusiast Joined Nov 5, '07 From California Currently Offline Reputation: 0 (0%) |
Hey guys my Gauges stoped working. Only the gas gauage seems to work fine and read fine. The others are just plain dead. I was thinking the fuses are blown or a cable was damage. What do I do to fix this?
Mar 31, 2009 - 7:29 PM |
Enthusiast Joined Aug 12, '07 From Lancaster, Pa Currently Offline Reputation: 35 (100%) |
if it was a fuse nothing would work...? um you can test it with a multimeter. if you want a new cluster i'll get you one out of a 94 gt coupe. let me know.
Mar 31, 2009 - 7:40 PM |
idk if it was a fuse or not i still havent check those, what do i need to check to know whats wrong? cables? other stuff?
Mar 31, 2009 - 8:11 PM |
well start there. there one set of fuses under the driver's side vent. the gauge fuse is a ten amp. there is also a set of fuses in the engine bay, i forget if any of them have to do with the cluster. i would check at the fuse with the multi meter. start there and then begin to eliminate the possibilities. it sounds like it is a problem with the speedometer and tach though. do the lights and turn signal indicates work?
Mar 31, 2009 - 9:09 PM |
well start there. there one set of fuses under the driver's side vent. the gauge fuse is a ten amp. there is also a set of fuses in the engine bay, i forget if any of them have to do with the cluster. i would check at the fuse with the multi meter. start there and then begin to eliminate the possibilities. it sounds like it is a problem with the speedometer and tach though. do the lights and turn signal indicates work? yeah all the turn signals and lights work perfectly, could the computer be failing? i hope not :[ .. i was pulling the sensor that goes in the intake cuz it was stuck but idk if that caused the problem |
Mar 31, 2009 - 9:22 PM |
well it's not your fuse. it's either the gauges don't work one of the wires could be bad, or a computer issue... if you want i will get you a cluster from a local junk yard. i'll go saturday. let me know if you want them.
Apr 1, 2009 - 12:59 PM |
Enthusiast Joined Mar 26, '09 From Longmont, CO. Currently Offline Reputation: 0 (0%) |
id still check the fuses, i've seen weirder stuff happen with guages. lol
-------------------- Lift Addict!! ^_^
Apr 1, 2009 - 5:31 PM |
so if i were to take to get it checked, would i need to take it to an electrical shop or normal mechanic?
This post has been edited by DatDudeDEnd: Apr 1, 2009 - 5:32 PM |
Apr 1, 2009 - 8:48 PM |
you can take it to a mechanic. do you have any friends who know their way around cars?
Apr 2, 2009 - 2:41 AM |
yeah, and even at a parts store if u buy a pack of fuses it will come with a fuse tester, or just use a test light, those will tell u if u are getting power to both sides of the fuses
Lo-Fi Version | Time is now: January 11th, 2025 - 4:40 AM |
