> Dented Toyota Oil Filter
post Apr 2, 2009 - 9:27 PM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
I just received a bunch of parts from 1sttoyotaparts.com and one of them was a Toyota oil filter. After some research online, it turns out that these are actually quite well made so I thought I would give it a try. When it arrived, I noticed that it had a dent in the top.
Here are a couple links to pictures of the filter:
Now from what I have read online, it seems that people are 50/50 on whether it is safe to use a dented filter. What do you guys think? Will that dent cause any performance issues with the filter? From what I know, the bypass valve is on that end of the filter, but is that dent in a place where it would affect the function of the valve?
Replies (1 - 9)
post Apr 2, 2009 - 10:00 PM
6strngs
Joined May 12, '06
From Wilmington, NC
meh, it seems pretty minor. As long as there's no puncture in it, I would still use it on my car if it were me.
post Apr 2, 2009 - 10:14 PM
RavenAegis45
Joined Jun 25, '08
From CA
yeah only if its a deep dent that would restrict flow then I'd be a little worried but thats minor, doubt it'll have any real effect, I say its good to go
post Apr 2, 2009 - 11:26 PM
so what else did you get?
post Apr 3, 2009 - 1:59 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
100% fine. go for it.
post Apr 3, 2009 - 2:57 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
shouldn't be much of a problem. i guess you can contact them and see what they can do.
post Apr 3, 2009 - 5:55 AM
trdproven
Joined Aug 2, '05
From Guam
minor
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 3, 2009 - 9:14 AM
reko
Joined Apr 17, '07
From Montreal, QC, Canada
seems as deep as the plastic itself
post Apr 3, 2009 - 10:45 AM
Sinyk
Joined Oct 4, '06
Thanks for the opinions guys. I guess it should be safe to use!
What else did I get? Lets see:
Valve cover gasket. I think mine may have a leak out the backside, but I can't tell for sure so I figure I'll take it off, clean it up and see how things are doing inside.
Valve cover goo. (FIPG)
EGR Modulator. I was still getting an EGR code being thrown so I figured I'd replace a few more related parts.
Hose from Modulator to EGR. The original hose fit a lot looser than the new one.
Engine Name plate. Mine is all scratched up from those plastic clips that hold the spark plug wires in place.
PCV Valve.
...because this
is just gross.
PS: Pictures are a lot more fun than just writing down what I got. smile.gif Also, I got all of this for about $70 less than the local Toyota dealer wanted for JUST the modulator.
post Apr 3, 2009 - 3:21 PM
6strngs
Joined May 12, '06
From Wilmington, NC
If that EGR code doesn't go away, try removing the valve itself and the tube going to it, then using some q-tips or something, clean out the passage-way where the valve connects to the manifold, and where the tube connects to the head. I had an EGR code too about 2 weeks before I needed to smog it and I replaced almost every component and nothing worked. then I tried this and it took care of it smile.gif
Lo-Fi Version Time is now: February 20th, 2025 - 6:53 AM
