> Projector Retro, It FINALLY stopped raining for 2 consecutive days!
post Apr 6, 2009 - 3:59 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
So I've been working towards this for a while, and I finally got the time and a dry weekend to complete my projector retrofit. This is my first time doing anything like this, so go easy on me! I used Rayme's lenses and his stickied How-To write-up for guidance. I took pix along the way sort of as an appendix to his write-up for those of us who do better with detailed visuals. I put clear lenses on all 4 headlights, but the pix below specifically pertain to the low beams, as the high beams is self explanatory.
Before:
Lense Removed from one of the low beams:
"Exploded view" of the components that make up the low beam internals:
Tiny stainless bowl of vegetable dip mix (!) and bathtub faucet ring for shroud and bezel use:
Cut out the bottom of the bowl for the lens to fit through:
Cut out the reflector to fit the back of the projector through - no turning back at this point!
Test fitting the projector. When I marked up the reflector to mount the projector, I removed the lens from the projector so I could make sure the cutoff shield was level. Then I test fit the projector in the reflector only, to make sure it bolted in correctly. Once I was sure that it was correct, I mounted the reflector back into the headlight bucket, tightened it in, and then drilled the projector mounting holes all the way through. By doing this, I'm able to adjust the alignment of the projector itself within the reflector.
Test-fitting the shroud I made. I had to cut a notch at the top of it to allow it to recess into the reflector without the glare shield mounting point obstructing it.
I also bent the bottom part of the shroud up to flatten it down some. The bent part doesn't show once it's in, but it allows the shroud to fit better into the reflector unit. I probably could have just cut this part out, but I wasn't sure how much of that would show, and I wanted to keep it as finished looking as possible.
Test fitting it over the mounted projector (still without the lens on it, so I didn't risk chipping or scratching the glass lens:
After.
This morning I learned that JB weld was a bad idea, as it doesn't bond metal to plastic well at all. Note the top part of the shroud on the passenger side. Now my celi has a lazy eye. Bummer. If I get home in time tonight, I will take it apart and figure out a plan B. It will probably involve using the mounting point where the glare shield went to screw the shroud to. The screw is small, and will probably not show at all, but we'll see.
Close-up of the driver's side. Other than the issue with the passenger shroud, I'm really happy with how they came out. Once I get the passenger side fixed, I will aim them and take night shots of the cutoff. It looks really good though and has nice color banding at the top.
Replies (1 - 19)
post Apr 6, 2009 - 4:10 PM
d0w0rkS0n
Joined Jun 10, '08
From Virginia beach
1994 Toyota Celica ST Turbo
1991 Toyota MR2
MySpace
post Apr 6, 2009 - 4:17 PM
96bluevert
Joined Mar 19, '07
From Washington
nice work!
This post has been edited by 96bluevert: Apr 6, 2009 - 4:17 PM
post Apr 6, 2009 - 4:25 PM
manphibian
Joined Oct 13, '06
From UK
Great Job!!!!
post Apr 6, 2009 - 4:42 PM
DEATH
Joined Dec 19, '07
From tx
Holy fcukin sh*t - nice job Griffy
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Apr 6, 2009 - 4:44 PM
rivets, that bonds well
post Apr 6, 2009 - 5:03 PM
GriffGirl
Joined Feb 7, '07
Yeah, I was thinking rivets
QUOTE (DEATH @ Apr 6, 2009 - 2:42 PM) *
Dude... seriously, it took a LONG time and a lot of work. I can see why people charge a lot for this mod, not to mention the cost of the projectors themselves. Luckily I made nice friends with this mechanic guy who gave 'em to me for nothin'. tongue.gif
post Apr 6, 2009 - 5:09 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
they look good, how's the beam pattern?
Also, your highs aren't going to work nearly as well since those are just us oem lights with clear lenses. Just incase you didn't know!
I would suggest that you do do something to the shroud. it would be really easy to smooth them out and paint them to match. I did it with one set, but idk where they went.
post Apr 6, 2009 - 5:25 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE (GriffGirl @ Apr 6, 2009 - 5:03 PM) *
EXT: WRC/TRD/404
post Apr 6, 2009 - 5:40 PM
GriffGirl
Joined Feb 7, '07
QUOTE (dustin15brown @ Apr 6, 2009 - 3:09 PM) *
Beam pattern looks potentially great. tongue.gif I haven't aimed them yet, so they're kind of all over the place, at least when parked 2 feet from the garage LOL
About the shroud - by paint to match do you mean paint them to match the color of the body of my car? I thought about that. I also considered smoothing them out to blend them with the reflector - how though? I don't have a vacuum but is there another way?
How can I make the high beams better? (LOL - I should've asked these questions a week ago, huh.)
post Apr 6, 2009 - 6:08 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (GriffGirl @ Apr 6, 2009 - 5:40 PM) *
Three letters: JDM!
Hahaha no, I'm just kidding. I was talking to Remy a few months ago about installing those lenses on my USDM housings. He said what happens is similar to a spotlight. The beam will be focused at one place instead of spread out. He told me they were still usable though.
The retrofit looks really good! I like it!!!
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Apr 6, 2009 - 10:43 PM
dustin15brown
Joined Aug 17, '03
QUOTE (GriffGirl @ Apr 6, 2009 - 6:40 PM) *
hahahaha 'potentially great' I dig it
You dont need a vaccum to smooth it out. Just fiberglass, sand paper, primer, paint *of the car or maybe to match the housing* It shouldn't be too hard, but when I did it I was 16 and they looked like ass.
You can't make the high beams better from anything I know. They will indeed look like a spotlight and are still usable, just something I hated when I had them on my car so I bought JDM highbeams
post Apr 6, 2009 - 11:33 PM
xs94st
Joined Aug 11, '07
From Corona, CA
Awesome work griff..good sense of ingenuity =)
A+ on the drivers side! Good luck with the aiming and fixin the passenger side, you'll figure out something that will astonish us =P
Pandelica 2.0 in progress.
post Apr 7, 2009 - 11:50 AM
GriffGirl
Joined Feb 7, '07
QUOTE (dustin15brown @ Apr 6, 2009 - 8:43 PM) *
so what is the difference between JDM highs and USDM highs, is it the reflector?
post Apr 7, 2009 - 1:26 PM
dustin15brown
Joined Aug 17, '03
I would ASSUME so, but don't quote me on that
post Apr 7, 2009 - 2:16 PM
GriffGirl
Joined Feb 7, '07
When you molded the fiberglass to make the shrouds, did you use a form to mold it to, or how did you do it? (I've never done fiberglass but then again I'm willing to try it)
post Apr 7, 2009 - 3:57 PM
SveNRG
Joined Dec 13, '05
From Amsterdam, The Netherlands
Respect for your work and originality. They look much better than original lights.
This post has been edited by SveNRG: Apr 7, 2009 - 4:05 PM
post Apr 9, 2009 - 5:14 PM
GriffGirl
Joined Feb 7, '07
QUOTE (SveNRG @ Apr 7, 2009 - 1:57 PM) *
laugh.gif laugh.gif laugh.gif Totally!
post Apr 9, 2009 - 9:46 PM
trdproven
Joined Aug 2, '05
From Guam
looks good except for the lazy eye. Just my 2 cents, entire lens does not look complete. It really looks like you retro fitted it. Why don't you get the transition completed from the outer to inner and it'll look stock and great.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 10, 2009 - 6:37 AM
Rayme
Joined Feb 18, '06
From NB, Canada
Nice one girl, you made your research well !
-Rémy
02 SiR, 08 250R
Lo-Fi Version Time is now: February 18th, 2025 - 6:52 AM
