> Oil Sending Unit Switch, Need some help here
post Apr 14, 2009 - 4:52 PM
6G96GT
Joined Jan 20, '08
From East Coast
My idiot light came on for the oil pressure. I do have an aftermarket gauge installed and it showed normal PSI. Anyway, when I went to install a new oil sending switch thinking it was faulty, the housing with the wire broke at the wire. How do I fix this? Cost to have it done professionally?
Replies (1 - 6)
post Apr 17, 2009 - 3:43 PM
Ryouxrs
Joined Mar 26, '09
From Longmont, CO.
if the switch is the part that broke just replace the switch
Lift Addict!! ^_^
post Apr 17, 2009 - 4:13 PM
6G96GT
Joined Jan 20, '08
From East Coast
no, it was the plastic switch's housing that you would snap back on to the switch once you replaced it. The housing has a wire going into it and the wire snapped out.
post Apr 17, 2009 - 5:51 PM
QUOTE (6G96GT @ Apr 17, 2009 - 4:13 PM) *
pm dr tweak, he can get any connector you want.
its a one wire thing, very easy to cut and splice.
post Apr 17, 2009 - 5:56 PM
Ryouxrs
Joined Mar 26, '09
From Longmont, CO.
QUOTE (presure2 @ Apr 17, 2009 - 4:51 PM) *
Lift Addict!! ^_^
post Apr 17, 2009 - 10:45 PM
6G96GT
Joined Jan 20, '08
From East Coast
thanks, will do.
I tried to pm dr tweak and couldn't locate his member name.
This post has been edited by 6G96GT: Apr 17, 2009 - 10:47 PM
post May 24, 2009 - 1:17 PM
6G96GT
Joined Jan 20, '08
From East Coast
Finally got it fixed. Had to go to a junkyard and snip the cap and wire from a Lexus that matched my sending unit. It tested and works perfectly. No more probs.
Lo-Fi Version Time is now: November 27th, 2024 - 10:51 PM
