> shimless buckets for a 5s
post Apr 21, 2009 - 4:16 PM
90gts5s
Joined Apr 21, '09
From lima oh
i was wondering if any one knew of shimless buckets that could be ran on a 5s. im doing a rebuild which will in time be turboed and wanted to replace the buckets while i had the motor apart. thanks for any help
Replies (1 - 9)
post Apr 21, 2009 - 4:39 PM
QUOTE (90gts5s @ Apr 21, 2009 - 4:16 PM) *
iirc the zz series engines are what the 3s guys use. and i do believe the shims are the same between 5s/3s
post Apr 21, 2009 - 5:12 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
I've read that the 3s guys use the 1zz shimless buckets, BUT I don't think it works for the 1st gen 3s right?? I mean you can interchange head parts between the 2nd gen and 3rd gen heads, but the 1st gen heads are totally different. IIRC the 3rd gens had shim-under bucket.
94 Celica gt white (sold)
post Apr 21, 2009 - 6:37 PM
Ryouxrs
Joined Mar 26, '09
From Longmont, CO.
prob a stupid question but what could be used on a 7a? same 1zz buckets, or am i just dreaming again? lmao
Lift Addict!! ^_^
post Apr 21, 2009 - 6:42 PM
QUOTE (Ryouxrs @ Apr 21, 2009 - 6:37 PM) *
i think the 7a uses the same size bucket as the 5s, steff (hurley97) knows for sure
post Apr 21, 2009 - 7:36 PM
Ryouxrs
Joined Mar 26, '09
From Longmont, CO.
QUOTE (presure2 @ Apr 21, 2009 - 5:42 PM) *
Lift Addict!! ^_^
post Apr 23, 2009 - 1:44 PM
90gts5s
Joined Apr 21, '09
From lima oh
i was told the shimless buckets would work if the head was 91+. the shim has to be a 31mm not the 28mm so we'll find out and ill be sure to post if it works.
post Apr 23, 2009 - 2:22 PM
darthripley
Joined Jun 17, '06
From dallas, tx
2nd gen 3sgte's use 2zz shimless buckets
i've heard that 1zz shimless buckets fit 5sfe's but i am not 100% sure & can't comment from personal experience.
'87 AW11 MR2 "Super R2" 4AG-ZE swapped Stage 1 Complete
'90 ST185 Celica All-Trac 3S-GTE "Vadar" Turbo AWD Sith Stage 2 in the works
'99 SXV20 Camry 5S-FE "Darth Maul" TRD Grocery Getter powah coming soon
post Apr 24, 2009 - 5:52 PM
alltracman78
Joined Aug 9, '06
From Ma
Gen II 3SGTE uses 1ZZFE buckets.
I don't know if the 2ZZGE has the same size or not, but if it's different it's not going to work on a Gen II 3SGTE.
post Apr 24, 2009 - 6:24 PM
darthripley
Joined Jun 17, '06
From dallas, tx
alltracman you're correct ... i got my ZZ motors confused - duh.
I did some searching around on mr2oc.com & 1ZZ MR-S shimless buckets will fit Rev2 5sfe's since they are 31mm & not 28mm like the earlier 5sfe motors which had "small" buckets.
Lo-Fi Version Time is now: February 18th, 2025 - 2:00 PM
