> engine noise through speakers/???
post Apr 26, 2009 - 3:09 PM
Candiiman
Joined Mar 10, '09
From pembroke pines FL
ok so idk if i post this up before. but i have this really annoying engine/whining noise that comes through the speakers. now i have a 800w amp and a 12' sub connected. ive changed both of them to see the out come but still gives that noise. i even put a sound filter on it and it does make it lower but its still there. any one have a clue of what it can be? plz help.ASAP!!!
Replies (1 - 7)
post Apr 26, 2009 - 4:15 PM
azian_advanced
Joined Apr 18, '05
From Calgary
your power wire to your amp shouldn't be next to the rca audio cables.. also, what kind of sound filter are you using? is it a ground loop isolator?
post Apr 26, 2009 - 6:18 PM
Candiiman
Joined Mar 10, '09
yes it is a ground loop isolater. and the wires are on seperate sides of the car. before they were together. but i seperated them months ago...
post Apr 26, 2009 - 6:32 PM
how long is your ground to your amp.
post Apr 27, 2009 - 9:14 AM
trdproven
Joined Aug 2, '05
From Guam
make sure you get a solid ground and seperate your audio RCA wires. RCA wires on right for example and power on left. Scrape down the metal to get better ground too. FOr the most part your ground is not good enough.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 28, 2009 - 12:21 PM
Candiiman
Joined Mar 10, '09
the ground wire is maybe two feet from the ground. im pretty sure that i have a solid ground. i will upload the pix when i get home!
post May 11, 2009 - 11:56 PM
itssteve
Joined Dec 14, '07
From yorktown Va.
i bet you its the radio, i had the rcas down the same side as my power wire for a while and had bad noise and switched the radio and it went away
post May 12, 2009 - 2:42 AM
trdproven
Joined Aug 2, '05
From Guam
QUOTE (Candiiman @ Apr 29, 2009 - 3:21 AM) *
short distance does not determine better ground, better contact does.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: December 2nd, 2024 - 5:58 PM
