> Changing valve shimms, alternative to the toyota SST
post May 4, 2009 - 10:14 AM
what have you guys used in teh past to change valve shimms. im not going to pull this engine again nor do i want to take out the intake cam so it need to be done like in the BGB.
Replies (1 - 8)
post May 4, 2009 - 10:41 AM
QUOTE (Smaay @ May 4, 2009 - 10:14 AM) *
iirc steff said the master tech at work made a tool instead of the sst, but im not sure what it is.
i had to remove the cams.
there is a vid somewhere of joeo from mr2oc doing it in the car with no special tools, i would check his ste, lovehorsepower.com
post May 4, 2009 - 12:05 PM
I used the lovehorsepower method.
Basically, you use an allen key to compress the valve, and then a flat head screw driver flipped on its side to hold it compressed by the edge of the bucket. Once you have everything in place, use a mini screw driver and a magnetic pickup tool to fish the shim out.
post May 4, 2009 - 12:23 PM
thats what i was thinking, sounds like a 2 person job. luckily the shimms are big. on a 2ZZ if you drop one it could fall in an oil jacket.
post May 4, 2009 - 6:54 PM
its totally a one man job. super easy to do.
post May 4, 2009 - 7:22 PM
DEATH
Joined Dec 19, '07
From tx
It sure would be cool if someone did a detailed how-to with pics for our site and our engines specifically. Mine, like most 3S's, is in need of an adjustment and I've never done it before.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post May 4, 2009 - 8:00 PM
alltracman78
Joined Aug 9, '06
From Ma
Probably not, unless you've changed something in the valvetrain.
The shims wear very little, even engines with 200K+ don't tend to be out of adjustment.
Adjustment is usually required when you change something with the valves, like valve seats, or a new cam, ect.
QUOTE (lagos @ May 4, 2009 - 12:05 PM) *
This is basically how I did it years ago before I worked for Toyota. Not that hard, but it takes a little bit to get used to it.
Definitely a one man job.
post May 4, 2009 - 8:29 PM
i will do a write up with lots of pictures this weekend. i need to do it soon. this thing sounds like a diesel truck
post May 7, 2009 - 4:38 PM
kel026
Joined Jan 5, '09
From York, Pa.
I am watching this with interest also. I just did a short block in mine and I must have got one or two shims mixed up because I can here one in there tapping away- A write up would be great!
Lo-Fi Version Time is now: December 3rd, 2024 - 3:39 PM
