> LSD AXLE VS TURBO AXLE HOW TO TELL, I think i bought the wrong one
post May 5, 2009 - 10:09 AM
02bluerolla
Joined Aug 31, '05
From Houston TX
Hey guys I have a 95 celica with a 2nd gen 3sgte and am doing a mr2 lsd swap. We have everything but the shifter cables, I cannot find st205 cables anywhere.... so i was wondering if there was a way to make mine longer or to make new ones. If anyone know where i can find the right cables or a place in houston where i can get them done pls let me know thanks!
This post has been edited by 02bluerolla: May 14, 2009 - 11:18 AM
Replies (1 - 16)
post May 5, 2009 - 10:14 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
just try and get the part numbers for the shirfter cable...ill do a search for them but its best if u can get the part number, toyota can usually order them for u.
post May 6, 2009 - 12:18 AM
look in the stickies. the part numbers are there
post May 6, 2009 - 7:52 AM
ra65_22re
Joined Aug 21, '06
From washington
This is the part # I found
33820-2B350.......... Shift Cables
post May 6, 2009 - 8:38 AM
something i dont know if you taken account for. the MR@ tranny has the gear selector shaft on the opposite side. its much easier to use an converted All-Trac tranny.
post May 11, 2009 - 1:56 AM
Dragondog
Joined May 10, '07
From Lubbock, Texas
QUOTE (Smaay @ May 6, 2009 - 1:38 PM) *
so will mr2 tranny not work then with st205 cables?....r will it stick tring to shift......whats the downside
also is it true that the back mount even off the gt wont work...it must be one from the st205?
and then of course with that tranny ull have to use hybrid shafts.....mr2 inners and st205 outers...right?
will the knuckles off the gt work for the st205 shaft r will that have to be changed too.....along with hub....
This post has been edited by Dragondog: May 11, 2009 - 3:10 AM
feedback
feedback
If I buy or sale please leave me feedback...thanks
cheap, quick, reliable, pick two
I treat my 6gc better then my own woman
post May 11, 2009 - 7:26 AM
QUOTE (Dragondog @ May 11, 2009 - 1:56 AM) *
its really not easier to use a converted alltrac tranny at all.
opening a tranny in anyway is definetly not easier than moving the gear selector to the rear and drilling 2 holes.
you need the 205 cables and mounts (yes, that means rear mount and bracket too), it dont matter which version of the e153 you use.
mr2 inners, alltrac outters. stock hubs.
post May 11, 2009 - 11:44 AM
anybody ever try using camry axles and shifter cables?
post May 12, 2009 - 3:30 AM
Dragondog
Joined May 10, '07
From Lubbock, Texas
k thx presure
feedback
feedback
post May 14, 2009 - 11:19 AM
02bluerolla
Joined Aug 31, '05
From Houston TX
QUOTE (Dragondog @ May 12, 2009 - 3:30 AM) *
k thx presure
I am almost done with my lsd swap but the driver side axles does not go in all the way. I think I got a turbo one instead of a lsd. I read here some where that they could be fix. can some one explain how please. and what excally need to be done.
post May 17, 2009 - 2:15 PM
Dragondog
Joined May 10, '07
From Lubbock, Texas
im not sure what u mean by either lsd or turbo.....from what i know all the turbos were lsd.....maybe i dont know the right answer but make sure you are using hybrid shafts..........mr2 inners, alltrac outters. stock hubs.........like presure said
feedback
feedback
post May 17, 2009 - 6:01 PM
QUOTE (Dragondog @ May 17, 2009 - 2:15 PM) *
LSD was an option on 93+ mr2T trannys.
if you dont know the right answer, why guess? your just spreading more misinformation.
post May 17, 2009 - 9:02 PM
QUOTE (02bluerolla @ May 14, 2009 - 12:19 PM) *
k thx presure
here's a pic of an LSD turbo axle and a non LSD turbo axle
which one do you have ?
post May 18, 2009 - 5:11 AM
Dragondog
Joined May 10, '07
From Lubbock, Texas
presure if u may reread...i didnt spread anything r even atempt to spread i simply said from what i know.....but was proven that turbo had both....as well as he said lsd and turbo...... not lsd and non lsd....what he said didnt even match up......dont go correcting me and then hit me with the ball.........if im mistaken then just correct me...i like it when you pitch to me but not when you peg me with the ball bro plz....thx
feedback
feedback
post May 18, 2009 - 5:45 AM
QUOTE (Dragondog @ May 18, 2009 - 5:11 AM) *
if someone needs to be corrected, and i know the correct answer, i WILL and DO correct people.
what you knew, was wrong, i corrected you.
no need to be offended or feel like i beaned you with the ball. lol
post May 18, 2009 - 9:17 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
**** Photobucket
post May 19, 2009 - 12:03 PM
Dragondog
Joined May 10, '07
From Lubbock, Texas
QUOTE (95CelicaST @ May 18, 2009 - 3:17 PM) *
lol yea it poped in my head......lol.........i know u correct ppl presure i know how u are....i dont mind being corrected its how i learn more.....but dont go sayin things like if u dont know the right answer then y guess.....when i said i may not know the right answer it was becuz i didnt know what he was sayin if he was saing non turbo has lsd and turbo didnt......he worded lsd and turbo as sepret as if there was one r the other anyway back on subject....
feedback
feedback
Lo-Fi Version Time is now: January 10th, 2025 - 4:42 PM
