> HELP ME GUYS OUT PLEASE!!!!, ideas??
post May 30, 2009 - 8:41 PM
legalkid86
Joined Dec 14, '08
From RGV, Texas
Hey guys well for the past week i have been having issues with my car turning on before it would turn on in one crank and everything was great, but this last past week i would crank it twice it would turn on sometime it would turn off when i would crank it the second time well i though it was due to i had not run it in a while so i checked the oil everything good, well today i was cranking it like 100 times and nothing at all and when i did turn it on it would die on me, well now i would really like to fix my car but the thing is i have no idea what is wrong with my car it does throw spark, but idk how else to diagnose for other issues so help me out here....thanks...guys please help out..!!
wAkE uP, u'Ll sLeEp WhEn U DiE.....
Replies (1 - 17)
post May 30, 2009 - 8:54 PM
Remy
Joined Jan 25, '06
From MN
You need air/fuel/spark to start a car check to make sure your getting all three. While cranking did you pump on the gas pedal ?? Could be a fuel problem since your getting spark but don't do it too much you don't want to flood it. Also check for check engine light codes (since your obd1) jump te1 and e1 with a paper clip and put the key to "on" while counting the blinks of the check engine light to determine what codes you get.
Make sure you battery is not dead too if the cars been siting for awhile.
post May 30, 2009 - 11:55 PM
legalkid86
Joined Dec 14, '08
From RGV, Texas
[quote name='Remy' date='May 30, 2009 - 8:54 PM' post='776769']
will this let me know me know if it is the timing chain or the fuel pump >?? if i were to use this method of diagnosing the problem??thanks for your help...
post May 31, 2009 - 12:13 AM
Stambo
Joined Apr 23, '08
From Muskego,Wi
i'm leaning more towards fuel pump issue more than anything
2nd Gen 3s-gte.... It lives!
97celiman
post May 31, 2009 - 12:17 AM
legalkid86
Joined Dec 14, '08
From RGV, Texas
QUOTE (Stambo @ May 31, 2009 - 12:13 AM) *
is there a way to access the fuel pump or to see it without dropping the tank i had a jetta a while back and it was under the back seat is that the same for ours??
post May 31, 2009 - 12:45 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE (legalkid86 @ May 30, 2009 - 10:17 PM) *
its under the rear seats.
get a fuel pressure tester and see if your getting the right fuel pressure at start up. This test will do more good then just opening up the fuel pump.
post May 31, 2009 - 2:34 AM
Joe_1985
Joined May 3, '09
From jacksonville/flemming island florida
im sorta new to 6th gens but i know on some toyotas you can jump the fuel pump via a connector or something under the hood
94 stx coupe, super mario kart beater
87 toyota 2wd truck, rebuilding engine
85 celica gt-s project
post May 31, 2009 - 7:28 AM
i doubt its the pump, but you can check it by using a peice of wire to bridge the FP and B+ pins in the diagnostics box in the engine bay.
whens the last time you did a tune up?
do you know how to verify the timing belt is still connected? (pull the distributor cap, verify the rotor is spinning when you crank the engine.)
if the belt is still good, you can verify timing is correct by setting the crank pully to 0, and check that the rotor is pointing at wire #1 or #4.
post May 31, 2009 - 7:30 AM
at the diagnostic connector, FP to E1 will kick it on.
post May 31, 2009 - 12:54 PM
legalkid86
Joined Dec 14, '08
From RGV, Texas
thanks alot guys ima go check it out and let you guys know ...thanks alot....
post May 31, 2009 - 2:45 PM
legalkid86
Joined Dec 14, '08
From RGV, Texas
hey guys well this is an update i went ahead and tryed to diagnose the problems and well now the problem is how do you konw the pause or like what may be wrong with it so if you guys would not mind i uploaded a video for you guys to tell me what you think the problem may be???
heres the vid:
post May 31, 2009 - 2:49 PM
legalkid86
Joined Dec 14, '08
From RGV, Texas
QUOTE (presure2 @ May 31, 2009 - 7:28 AM) *
hey pressure dude thanks alot....i did the FP and the B+ and the car turned right on. what does this mean and what do i need to change?? can it be the relay or is it the fuel pump?
post May 31, 2009 - 3:02 PM
legalkid86
Joined Dec 14, '08
From RGV, Texas
Pressure:
Now thanks alot now that i guess this has got me somewhere what would this mean the car turned on doing the FP and the B+
heres the link of the car turning on
post May 31, 2009 - 3:54 PM
fuel pump relay.
post May 31, 2009 - 6:05 PM
QUOTE (presure2 @ May 31, 2009 - 4:54 PM) *
fuel pump relay.
or wiring to the fuel pump, or wiring to the fuel pump relay, or the circuit that activates the fuel pump relay, etc.
post May 31, 2009 - 8:27 PM
legalkid86
Joined Dec 14, '08
From RGV, Texas
QUOTE (Bitter @ May 31, 2009 - 6:05 PM) *
fuel pump relay.
well guess what i changed the efi relay cause that is the only one in the fuse box nothing else has fuel pump replay on it, but idk it still does not turn on can you guys tell me what else to do and now i did that bypassing" now it does not turn on at all....i got another problem now help me out what else can i do??
post May 31, 2009 - 9:30 PM
iirc isnt there a green circuit opening relay behind the radio console thats part of the fuel pump circuit? i only have diagrams for a 7afe corolla on hand, should though be similar to your 7afe celica.
i'm seeing efi relay, clutch pedal/park neutral switch, circuit opening relay, several grounds and several power feeds. all needs to be checked.
This post has been edited by Bitter: May 31, 2009 - 9:37 PM
post Jun 1, 2009 - 11:20 PM
legalkid86
Joined Dec 14, '08
From RGV, Texas
QUOTE (Bitter @ May 31, 2009 - 9:30 PM) *
well buddy i still got problems now, guess what happened well i went to autozone bought a efi relay thinking that maybe the fuel pump relay had something to be related to it, it didnt work. when i changed it out now the weird thing is that i tried to bypass the fuel pump in the diagnostics box now it wont turn on at all and well i tried to do check for spark by getting someone to crank it and screw driver in the plugs to a ground and now i dont get any spark at all, now guys what can i do can it be my timing belt that maybe cause this problem keep in mind the problem i had before as well , please help me out guys thanks....
Lo-Fi Version Time is now: November 27th, 2024 - 8:18 PM
