> CEL on got the problem, now need help
post Jun 13, 2009 - 11:54 AM
97celiman
Joined May 22, '08
From dallas texas
so i threw a CEL P401 soooo here are the 6 things it could be
EGR valve stuck closed
open or short in VSV circuit for EGR
Vacuum or EGR hose disconnected
MAP sensor
EGR VSV open or closed malfunction
ECM
What is ECM and VSV?
i can check the hoses and like a dirty MAP sensor (can i have a dirty EGR valve hence the closed?)
i know you have to clean with non corrosive stuff (no brake cleaner) what does anyone recommend?
how do i know when its fixed, i know you can disconnect battery to reset computer and get rid of CEL or does the CEL go away after its fixed then disconnect to reset.
Any thoughts appreciated.
Replies (1 - 2)
post Jun 15, 2009 - 2:50 PM
97celiman
Joined May 22, '08
From dallas texas
so now the light will turn on and off. not rapidly, one day it will be on and one day it wont...very annoying. the car seems to be running fine so i am very confused.
post Jul 16, 2009 - 2:02 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
you most likely have carbon build up in the egr valve it just needs to be cleaned, you can take it to advanced auto and ask them about it, or any auto parts store. They should have something you can put in your gas to get rid of carbon build up, im going through the same thing, EGR flow, it sucks but it wont leave you stranded, you'll get worse fuel economy but that's about it.
Lo-Fi Version Time is now: February 23rd, 2025 - 8:32 PM
