> Oil in IC piping with smoke..., Whats the problem/WTD?
post Jun 16, 2009 - 10:33 PM
racer4street
Joined Jan 15, '08
From Knoxville, TN
I just bought another 6gen Celica with a turbo 5sfte engine. The car runs great other than the smoke (blue) that comes out between shifts (only under alot of boost). This morning i drove the car very easy without alot of boost and it did not smoke but later when i drove it and opened it up it started smoking really bad when i let of the gas to change gears, etc. I checked my PCV (con. hose only to see fluid) and it looked fine. Today i took the "U" IC pipe off the turbo and did not see any oil but tonight i took off part of the IC piping that goes to the intake and it has a bunch of oil in it...are my turbo seals bad or is the turbo bad? Any help would be great.
Replies (1 - 5)
post Jun 17, 2009 - 3:10 PM
TRD_Ian
Joined Aug 19, '08
From New Brunswick
do you have a catch can instaled? they will pervent that from happening, but you might need new seals i unno....i assume if it doesnt happed unless your are in high boost a catch can will solve it
i hate snow, missing my celica
post Jun 17, 2009 - 5:07 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
yeah sounds like turbo seals or is your breather run back to pre turbo intake? if it is then a catch can will solve your problem
Breaking Axles...
post Jun 19, 2009 - 1:02 PM
racer4street
Joined Jan 15, '08
From Knoxville, TN
QUOTE (TRD_Ian @ Jun 17, 2009 - 4:10 PM) *
How do i install a catch can on the 5sfte engine? From PCV valve ("T" connection) to catch can and from catch can to intake manifold or what?
post Jun 19, 2009 - 3:07 PM
my money is on bad seals in the turbo. it needs a rebuild.
post Jun 23, 2009 - 9:36 AM
racer4street
Joined Jan 15, '08
From Knoxville, TN
A new oil catch can fixed the problem and runs GREAT! Thanks for the help.
Lo-Fi Version Time is now: February 22nd, 2025 - 12:40 AM
