> How do I remove the header heat shield?
post Jul 13, 2009 - 10:56 AM
Tech-Nics
Joined Jun 18, '08
I am trying to remove my heat shield over the header but the bolts are completely rusted and now the bolts are stripped while I was trying to take them off with a 12mm socket. I also added WD40 to try to loosen them up. No luck. Any ideas? I'm trying to take the shield off cause I'm going to be putting on a new header very soon.
Thanks for any help.
Replies (1 - 3)
post Jul 13, 2009 - 11:05 AM
DEATH
Joined Dec 19, '07
From tx
If you have stripped the hex on top about the only thing you can do now is to get a good set of vicegrips, some PB blaster to loosen it and get on it. I'd make sure the vicegrips are good and tight the first try cause if you end up making those buts totally round you're gonna be hating it.
Let the PB Blaster sit for a while before you go at it with the vicegrips
This post has been edited by DEATH: Jul 13, 2009 - 11:05 AM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jul 13, 2009 - 11:25 AM
dgbldr
Joined Sep 19, '08
From Michigan
Vise grips are a long shot for something like that. Soak it real well and try an extractor:
http://www.amazon.com/gp/product/B0000CCXV...8T9JSNJ8P07AQSQ
post Jul 13, 2009 - 6:04 PM
Tech-Nics
Joined Jun 18, '08
got it off with a lot of arm power...
thanks guys
Lo-Fi Version Time is now: February 22nd, 2025 - 2:21 AM
