> Exhasut Line modification??!!!, 2 Muffler on one exhaust???
post Aug 8, 2009 - 12:15 AM
lilpmp
Joined Aug 6, '09
From Quebec
Hi guys, i was wondering if it would be possible to Delete my resonator, put the stock muffler (with modification) instead, and put a fireball exhaust(jdm style) in the place of the stock muffler...
because here in QUebec its illegal for us to have Louder muffler than original one, so if the sound is cutted by the stock one, then the second muffler will not make any noise? or a tiny tiny rumble???
Because i really like the look of the side up exhaust...But i dont want no ticket!!!
If u have any suggestion i would really apreciate it!!! thanks!
Replies (1 - 13)
post Aug 8, 2009 - 3:46 AM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
QUOTE (lilpmp @ Aug 8, 2009 - 12:15 AM) *
resonator tones down the sounds, deleteing it will give u an annoying raspy sound, you would be better off chopping off your factory muffler and adapting the 1.75" piping to fit a 2.25" inlet JDM style muffler, its still going to be a little louder though
post Aug 8, 2009 - 9:04 AM
lilpmp
Joined Aug 6, '09
From Quebec
and if IF keed my resonator, my stock muffler, and put a jdm pipe after??
I mean customizing all my exhaust line, but will i too much restriction, or it will be ok because those pipe are free flow
post Aug 9, 2009 - 12:26 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
You can get a silencer for you muffler unless its one of those that have a built in silencer that you can adjust, I have 2 mufflers on my accord and its freakin loud with those fart cannons although its a V6.
post Aug 9, 2009 - 12:54 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Bad info in this thread.
Yes, you can actually place a canister muffler after a straight-through resonator, then run the pipe out to a larger canister muffler in the back. Its done all of the time. Basically, it would go: Cat-resonator-muffler-muffler. It is the only way to supress the noise without having a negative effect on exhaust flow.
Also with using a canister muffler under the car you can delete the resonator completely without getting a raspy sound. A straight through canister muffler is essentially a very large resonator.
**** Photobucket
post Aug 9, 2009 - 12:58 AM
Mstoochn
Joined Apr 27, '09
QUOTE (95CelicaST @ Aug 9, 2009 - 1:54 AM) *
i beg to differ,
magnaflow sport series muffler without resonator : http://www.youtube.com/watch?v=SSgAnHPp-A8
sounds like crap
post Aug 9, 2009 - 1:01 AM
95CelicaST
Joined Feb 5, '05
If you re-read before flying off the handle you would see that I said you can delete the resonator, so long as you're using a straight through muffler under the car (that means two mufflers).
Yes that sounds like crap.
**** Photobucket
post Aug 9, 2009 - 9:32 AM
lilpmp
Joined Aug 6, '09
From Quebec
I was thinking about that and i dont wanna spend money customizing all my exhaut line juste to make it quieter without adding perfomance !!
I will see how the car sounds when ill remove the stock muffler, with still the resonator on
IF its still quiet ill put the jdm pipe, and if needed i was thinking about modifing the Silencer addon, to make it longer or with a smaller hole at the end, so and when
ill go downtown ill just put the silencer on and everything should be allright, ill take some videos when it will be done,
But I will do the Exhaust job after i received and installed my Header!!
By the way sorry for my English, i usually talk French
Thank You !!
post Aug 9, 2009 - 3:00 PM
domyz
Joined Jul 29, '07
From Quebec, Canada
I did it, I have the CT20B - Downpipe 3" - No cat - borla proxs center - borla proxs back all in line and i'm from Trois-Rivières, Quebec, really quiet
If you wanna hear it, send me a private message
post Aug 10, 2009 - 1:18 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Ack -- why can people not tell the difference between resonators and mufflers?
A resonator is not a muffler. It's an echo chamber. Tap on yours, it'll ring like a bell. It bounces soundwaves into each other, cancelling the noise out. Great for smoothing the tone of one's exhaust, only good at reducing the volume. They come stock.
A straight-through muffler is often mistaken for a resonator because they're both cylinders. Aside from the exterior shape, however, they are nothing alike. A straight-through is packed with insulation behind a perforated centre pipe. This absorbs sound. If you have one and tap on it, you get a dull response. Straight-throughs are great at reducing the volume with minimal flow impairment, and offer the flexibility of greater noise suppression with a longer body. However, they will not smooth the tone nearly so well as a resonator.
If you want a muffler for looks on the end, without compromising volume, I'd suggest adding a straight-through round-body muffler after your resonator, and then stick whatever muffler you want on the end of the pipe. It won't sound the same, but it shouldn't be notably louder.
post Aug 10, 2009 - 10:47 AM
lilpmp
Joined Aug 6, '09
From Quebec
OK like puting these kind off muffler http://www.performancepeddler.com/detail.a...UCT_ID=MAG14416
After the reso and then put the jdm pipe?
post Aug 16, 2009 - 4:00 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
QUOTE (domyz @ Aug 10, 2009 - 8:00 AM) *
turbos suppress engine sound, u cant compare.
for example. we have ss3 (3s-ge) and gt4 (3s-gte) - the ss3 has a 2" exhaust with a rice cannon and its louder than the gt4 which has a 3" exhaust and an even bigger rice cannon
Mike W
269awhp / 273ft-lbs
post Aug 18, 2009 - 9:02 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
A turbo, by it's very nature of sticking metal blades into the exhaust stream, effectively does the same thing to the exhaust stream as the baffled mufflers used on pretty much every stock engine. They slow the flow down dramatically. Slow-moving exhaust streams are by their nature quiet, which is the primary reason a car's exhaust gets louder as engine RPMS increase or as you remove restrictions on the flow.
That's why straight-through mufflers and resonators, although different technologies, are both well-regarded. They reduce volume without greatly impinging upon smooth exhaust flow, ending the traditional balancing act between efficiency and acceptability.
post Aug 20, 2009 - 4:13 PM
lilpmp
Joined Aug 6, '09
From Quebec
O My god, Iv removed the stock muffler 2day to see whats was the sound with only the resonator on, So Loud and Crappy, I cant put my pipe directly on it.. I have to keep my stock muffler and put it after ho well. maye ill juste forget about it
Lo-Fi Version Time is now: November 23rd, 2024 - 9:30 AM
