> Diffuser on 6G
post Aug 28, 2009 - 3:22 AM
yellowchinaman
Joined Aug 11, '08
From London
Just out of curiosity. Has anyone in the US or in Europe installed or fabricated a Diffuser for their Gen6?
We've fitted a universal Diffuser to our GT-Four however looking at re-designing a Celica specific due to its low tank.
4 Pages V   1 2 3 > »
Replies (1 - 19)
post Aug 28, 2009 - 8:30 AM
I've been thinking about doing this, but have yet to actually fabricate one since my car is not at that stage yet. I'd be very interested to see what you come up with.
post Aug 28, 2009 - 9:15 AM
yellowchinaman
Joined Aug 11, '08
From London
well we've fabricated a universalone which is very effective to improve air flow. However the GT four has a low down tank and is not in line with the bumper so brackets to maintain a 11 degree slope is necessary for maximum air flow efficiency.
On a normal non GT four Celica it should fit flush because it downt have a low tank and should look a little bit like this:
We've sold many to Silvia owners already as it's a univeral diffuser.
This post has been edited by yellowchinaman: Aug 28, 2009 - 9:17 AM
post Aug 28, 2009 - 9:18 AM
what are the benefits?
post Aug 28, 2009 - 9:34 AM
99GT
Joined Dec 14, '06
From MN, USA
post Aug 28, 2009 - 11:15 AM
Culpable04
Joined Apr 17, '06
From New Jersey
the aerodinamics of a car are important over and under the car, a smooth flat surface would be the best thing for the underbody, that way the air travels underneath without turbulance or drag, thus improving handling, and overall driving. a difuser helps to get the air to come out easier from the underbody,, most facorty rear bumpers at as a parachute, trapping air.
post Aug 28, 2009 - 1:46 PM
What a underbody panel does with an inclusive rear diffuser is simple physics.
smoother and less turbulence means the air moves faster under the car than the air over the car. This creates a LOW pressure zone under the vehicle and a High pressure zone (slower moving air) above the vehicle. These pressure zones give down force to the car. The more down force you have the better you perform.
post Aug 28, 2009 - 2:27 PM
QUOTE (njccmd2002 @ Aug 28, 2009 - 10:18 AM) *
post Aug 28, 2009 - 2:48 PM
yellowchinaman
Joined Aug 11, '08
From London
OH MY GOD! You guys are amazing. Everyones logic is dead on and I couldnt explain it any better.
We've has many cocks going on about down force from the diffuser alone and bragging their knowledge of rocket science trying to put us down acting like they know it all.
Truth is this alone doesnt do that much. The car we're building just had coil overs on and now lowered. We're making a front splitter and skirts and under tray to complete the set.
However this does greatly improve the air flow from the GT4 because there is alot of drag under the rear bumper of the GT4.
This post has been edited by yellowchinaman: Aug 28, 2009 - 3:28 PM
post Aug 28, 2009 - 2:52 PM
Every little bit of function counts.
This post has been edited by playr158: Aug 28, 2009 - 2:52 PM
post Aug 28, 2009 - 3:53 PM
yagamius
Joined Feb 18, '09
From Costa Rica
Diffusers are very effective to the aerodynamics of the car, the air need to flow under car as much over car, high wing helps to keep the car in the ground, diffuser makes help to to improve response.
if can have one of those I definitely have it on my car, the only difference will be that I'll try to make it wide as the back of the car
1994 ST Celica --> no swap --> 7A rebuild
1974 Mustang --> Almost Restored
post Aug 28, 2009 - 4:08 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Find a way to utilize OEM bolt locations and you'll have a winner. I'm not too interested if it involves riveting it through the car.
**** Photobucket
post Aug 28, 2009 - 9:23 PM
post Aug 28, 2009 - 11:52 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
if anyone decided to mass produce ill be in a group buy for sure. (front or rear)
GRX133 Toyota Mark X 350s
post Aug 31, 2009 - 2:44 PM
yellowchinaman
Joined Aug 11, '08
From London
QUOTE (yagamius @ Aug 28, 2009 - 4:53 PM) *
Basically we for te GT4 it needs to cover from the tank to the bumper. If we made a wide one from the tank to the bumper, the rear arms get in the way. 1 Way to obercome this is by having jsut the middle from tank to bumper and the ends extended abit likea T shape. However in doing so you end up making a massive scoop on the ends where trapped wind becomes a drag eleminating the entire idea.
QUOTE (95CelicaST @ Aug 28, 2009 - 5:08 PM) *
As the GT4 was a rally car it never intended to have a diffuser and undercar airdynamics wasnt really something they considered too well.
The two end brackets are bolted to the OEM under bumper bolts and only the tank under guard needs drilling to mount the front part of the diffuser. No big deal and it doesnt cause any strain to what its attached to.
QUOTE (njccmd2002 @ Aug 28, 2009 - 10:23 PM) *
Made of 2x2 twill carbon fibre. Weighs less then 5KG.
QUOTE (Cuts_the_Pilot @ Aug 29, 2009 - 12:52 AM) *
Not that I'm trying to put in the sales but we're already mass producing them and selling it in other forums and on our website.
Back to the origional post. Has anyone every tried making one apart from us because I'd like to compare findings and see if we can a make GT4 specific one.
post Aug 31, 2009 - 5:59 PM
Cuts_the_Pilot
Joined Dec 15, '02
if you make a gtfour specific one hit me up because im a definate buyer.
As a matter of interest is it any more stable at high speeds?
This post has been edited by Cuts_the_Pilot: Aug 31, 2009 - 6:00 PM
post Sep 1, 2009 - 2:43 AM
yellowchinaman
Joined Aug 11, '08
From London
QUOTE (Cuts_the_Pilot @ Aug 31, 2009 - 6:59 PM) *
It does feel alot smoother at high speeds. I went up to 130mph and there is alow less sway how ever we did just change to coil overs too so. For sure there is less noise in the rear though.
post Sep 1, 2009 - 3:41 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
QUOTE (Cuts_the_Pilot @ Sep 1, 2009 - 12:59 AM) *
x2
post Sep 1, 2009 - 7:50 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
so basically add a diffuser on the bottom of my car and if i go fast enough i can create lift and fly? laugh.gif , anyone add jet engines on their celica yet, that big trd wing has to be used for flight stability right, am i right?
post Sep 1, 2009 - 8:04 AM
QUOTE (freddy121389 @ Sep 1, 2009 - 8:50 AM) *
a diffuser creates downforce....which is the OPPOSITE as lift.
and stop being a retard and cluttering one of the FEW good threads on this forum
4 Pages V   1 2 3 > »
Lo-Fi Version Time is now: November 23rd, 2024 - 6:37 AM
