> Installing KYB Inserts, Fluid inside front strut???
post Sep 15, 2009 - 9:50 PM
Davesceli
Joined Apr 24, '04
From S. Cali
I've pretty much got all of it down, but i've heard about some kind of liquid inside the front tube...what exactly is the liquid and what should i replace it with should i spill it or something?
Replies (1 - 9)
post Sep 15, 2009 - 11:53 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
You shouldn't have liquid to worry about. The cartridge should be sealed.
Although if you feel that you must replace any water that's gotten between the cartridge and the carrier make sure you replace it with deionized water. It won't rust the metal as badly as tap or saltwater will.
post Sep 16, 2009 - 12:28 AM
fibrewizard
Joined Sep 8, '09
From australia, east coast
i put a kyb insert into my 5th gen.....
if the liquid u are talking abount is the shock fluid..... then just tip it into a container..... clean and slip insert in tighten up top and put spring back on.......
st184 3vz-fe convesrion complete
st185 AWD 3vzfe turbo conversion in progress
and stock st204 daily....
post Sep 16, 2009 - 3:16 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
The cartridges are sealed, but the struts are filled with a very thin oil -- for heat dispersion. Air is not a good conductor. The oil transfers heat away from the actual shock (the cartridge in rebuildable struts), improving function and prolonging life.
KYB recommends simply capturing the oil from your struts and re-using it, so be careful when taking the gland nut off, and of course use a very clean container to collect it.
Keep in mind the oil's not there for lubrication so viscosity isn't the issue and it hasn't been subjected to the kind of use which breaks down engine oil. And as a side note, do not use engine oil as a replacement. Motorcycle fork fluid will do, but it'd cost dearly.
post Sep 16, 2009 - 10:13 AM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
Wouldn't some sort of heat conducting grease work best? When I took mine apart I didn't find any fluid. Maybe it had all leaked out.
post Sep 16, 2009 - 12:42 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
http://kyb.com/service/installationtips/in...lationtip08.php
God made man....
Everything else...
Made in China
post Sep 16, 2009 - 1:18 PM
Joe_1985
Joined May 3, '09
From jacksonville/flemming island florida
use brake fluid
94 stx coupe, super mario kart beater
87 toyota 2wd truck, rebuilding engine
85 celica gt-s project
post Sep 16, 2009 - 2:52 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
Never put anything. Thats what kyb recommends
God made man....
Everything else...
Made in China
post Sep 16, 2009 - 6:17 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
ha too late, i put a little bit of used motor oil when i did put blisten inserts.
post Sep 16, 2009 - 8:15 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (BonzaiCelica @ Sep 16, 2009 - 4:17 PM) *
ya, i saw it on youtube on blistein inserts, they put oil on it but im not sure if thats manufacturer recommended.
God made man....
Everything else...
Made in China
Lo-Fi Version Time is now: January 11th, 2025 - 7:48 AM
