> Rear left speaker bracket for convertible?
post Sep 23, 2009 - 9:17 AM
magnetopulse
Joined Sep 11, '09
From Northern Virginia
Hi,
I went to put new rear speakers into my 95 Convertible to discover there is no speaker bracket on the left hand side (as well as no speaker). I called the local dealer and they said this part is not available.
Does anyone have any idea where to get hold of one of these? Or the part number? Or have one from a car they are parting?
Thanks in advance for your help,
Rod
Replies (1 - 5)
post Sep 23, 2009 - 11:57 AM
pyeatts
Joined Jun 9, '09
From Saint Louis
Rod,
To start with your local toyota dealer sucks whoever they are. Parts for the 6 generation are available everywhere. However you may want to try the salavage yard system as new speaker brackets are around $150 a piece. But if you have the juice here's one dealer I have worked with for years and they can get anything. http://www.trademotion.com/partlocator/ind...m?siteid=214314
For salvage yard parts this request form seems to work best: http://www.carsandpartsrequest.com/cgi-bin...r/requester.cgi
Good luck!
Phil
post Sep 23, 2009 - 4:53 PM
pyeatts
Joined Jun 9, '09
From Saint Louis
Rod,
If you need a diagram for what goes with that speaker setup use this link: x7d8V
http://www.trademotion.com/partlocator/ind...playCatalogid=0
This post has been edited by pyeatts: Feb 25, 2010 - 12:03 AM
post Sep 24, 2009 - 9:38 AM
magnetopulse
Joined Sep 11, '09
Wow, thanks for that info. I can't believe that piece is $150. Since I have one on the right side, I've taken it out to have a look at it. If I can't find one at a scrap yard, I'll make one myself.
Thanks!
Rod
QUOTE (pyeatts @ Sep 23, 2009 - 5:53 PM) *
Rod,
post Sep 25, 2009 - 9:22 PM
chucho
Joined Mar 23, '03
From New Orleans
I can pull out the bracket one day and let you have it if you want it. I wont be using the back speakers. w my competition setup. So let me know and I can try to set it up.
post Sep 29, 2009 - 10:29 AM
magnetopulse
Joined Sep 11, '09
Thanks, that sounds great. Do you have a speaker bracket for a convertible or will the one from your Coupe fit?
Cheers,
Rod
QUOTE (chucho @ Sep 25, 2009 - 9:22 PM) *
Lo-Fi Version Time is now: February 23rd, 2025 - 5:33 PM
