> Oil Question
post Oct 4, 2009 - 4:33 PM
6G96GT
Joined Jan 20, '08
From East Coast
I bought an oil drain bolt from Autozone and it came with a light blue rubber gasket. When I removed the original oil drain bolt, it was all metal and no gasket. Anyway, I completed the oil change and ran the car around the block. Oil level is good and there's no oil on or around the new oil drain bolt with the gasket. I should be all set right??
I did hand tighten the new bolt with gasket and gave it a 1/3" turn (a bit more than 1/4" because I figured the gasket would crush and seat a bit more than if it were just a metal bolt).
This post has been edited by 6G96GT: Oct 4, 2009 - 4:34 PM
Replies (1 - 4)
post Oct 4, 2009 - 5:36 PM
trdproven
Joined Aug 2, '05
From Guam
you shouldn't have any worries, sometimes cars have gaskets sometimes they don't but either way they all work. If you noticed it takes a good unloosen on the bolt for oil to drip out. your pan would have to be warped or wack at the drain bolt hole for it to cause leaks.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 4, 2009 - 5:44 PM
6G96GT
Joined Jan 20, '08
From East Coast
Alright, sounds good. Thanks!
post Oct 4, 2009 - 10:22 PM
my 7afe never had a gasket and never leaks. who knew!
post Oct 5, 2009 - 4:18 PM
6G96GT
Joined Jan 20, '08
From East Coast
Well, I checked my oil drain bolt gasket after driving home today and it was a tiny bit wet so I turned the bolt another 1/2" turn and it seated tightly (but not too tight).
Also, I noticed some oil along the side of my oil pan where the drain bolt is and noticed a couple bolts at the bottom of my intake manifold were wet as well (possibly from getting sprayed)??? I don't think it's an axle seal because I had that replaced about 4 months ago. Any thoughts on what it could be? It's not enough to leave any signs on the pavement when parked oddly enough.
Lo-Fi Version Time is now: December 4th, 2024 - 5:53 PM
